08-03-2011, 04:24 PM | #1 |
My A misses at cruising speed... Any ideas?
Just as the title says, I am experiencing a miss at cruising speed. Not anything I can really feel, but I can hear it. Car starts and idles perfectly, no other issues whatsoever. I have tried messing with the GAV, but there's no change. It has been getting worse the past few months then my el cheapo condenser died on me. I replaced it with a Henry condenser, regapped the points, and plugs last week. (hoping I would fix the miss also) It is running smoother than ever, but I still have that miss. It's frustrating, and annoying. Would anyone have an idea where to start searching?
All ignition wiring is good Cleaned the carburetor out as well Plugs gapped at .030 Points gapped at .018 I'm clueless.... Last edited by AstroZombie; 08-03-2011 at 04:30 PM. |
08-03-2011, 05:22 PM | #2 |
Re: My A misses at cruising speed... Any ideas?
Try 35 on plugs. and check gap on cap to rotor all four.20-30. may have a crack in cap.
www.whidbeymodelaclub.com |
08-03-2011, 05:41 PM | #3 |
Check the point gap on each cam lobe. It is possible for the distributor cam to be worn enough on one lobe to cause a miss.
08-03-2011, 05:43 PM | #4 |
Have you checked coil polarity ?? Improper polarity can reduce secondary voltage by 15-30% causing a high speed mis-fire..
Check this;http://www.chicagolandmgclub.com/tec...neral/574.html |
08-03-2011, 05:56 PM | #5 | |||
Thanks all who replied. A "miss" is difficult to troubleshoot since there are so many variables. I appreciate the insight. |
08-03-2011, 06:03 PM | #6 |
"The wear block on the point is badly worn. I planned on replacing points..." "I have not checked the coil. It is old and crusty..." And you wondered why it was missing? |
08-03-2011, 06:32 PM | #7 |
If the miss is intermitent check the shaft for any deflection also.
08-03-2011, 08:47 PM | #8 |
I had a high speed miss a few years back and it took a while to find the problem. the problem turned out to be a new repro dist. cap body. The plastic or what ever the repro caps are made of was thin in the area above where the number 4 contact wire goes through the cap. At higher rpm it was crossfiring to the number 3 plug wire-strip through the thin spot in the plastic where the number three plug wire-strip passed over it. I only noticed the miss at higher speed. One night I had the hood up with the engine running, I reved it up pretty good and I could see the sparks and discovered the problem that had tormented me for a couple of months or more.
08-03-2011, 11:51 PM | #9 | |
Haha, yeah you're right! A lot has been falling behind recently. The money needed to fund my addiction hasn't been good. I'll do a legit "tune up" and see if it still misses. Thanks guys, I appreciate the help. |
08-03-2011, 11:54 PM | #10 | |
08-04-2011, 02:48 AM | #11 |
I've seen a couple distributor caps that short internally between the contact leads. That can be hard to find, since you don't see any sparks, and it may only show up at speed or under load, when the plugs need more voltage to fire.
08-04-2011, 10:56 AM | #12 |
There was a thread on the old barn that reported "point bounce". It seems that the points spring was not very strong and when the engine sped up the points would no longer ride on the cam and would "bounce" over a lobe or two causing a miss.
08-04-2011, 11:28 AM | #13 | |
I once worked on a friend's '48 Chrysler Windsor 6. He had tuned it up at some point in time and it had not run right since. The car had a great idle but would not run over 1500 rpm no matter what was done to it. Over a period of years he had done a ton of work on this car including complete fuel system overhaul to try and fix the problem. Well, turns out that the points were replaced with a national name brand (he still had the box with the old points) but there was no spring at all on them. Only the copper contact strip was opening and closing the points. I installed the old points and the car ran fine. |
08-04-2011, 11:56 AM | #14 |
Check the amp meter and or loose wires going to amp meter!!
mike |
08-04-2011, 12:46 PM | #15 |
Your Spark rod could be bent and is too close to the spark plug when your advanced all the way. Arcing will occure between the two. Also if you have just a key and the metal cable for the ingnition,the cable will sometimes arc against the head. look for this in the dark,motor running. wouldent hurt to wiggle a few wires and see if you get a arc. Ive been thru all of this.
Wick |
08-04-2011, 03:08 PM | #16 | |||
Thanks again for the suggestions. I really do appreciate it. |
08-04-2011, 04:35 PM | #17 |
I would not buy the round cap. I've never had a problem with the one cap I bought from Bratton's and the one cap I bought from Little Dearborn in Minneapolis. They both fit the metal body nice and tight and never had any crossfire.
08-04-2011, 05:34 PM | #18 |
The problem with the round modern type cap is that you can't acurately measure and set the gap between the rotor tip and the contacts in the cap. I had one that was jumping about because the rotor tip was hitting some of the contacts in the cap. The rotor tip can be filed down but the gaps will vary, you can't see them to measure the gap.
