11-14-2022, 03:32 PM | #1 |
Holley 94
Hello good people. Does anyone know if the idle jet(H32?) has a 3/8-24 thread? Thanks in advance.....
11-14-2022, 05:53 PM | #2 |
Re: Holley 94
If you mean the actual idle tube/jet that screws into the bowl side of the nozzle bar, it's a special 1/4-32 thread.
If you mean the brass fitting (air bleed) in the middle of the nozzle bar it's also a speacial thread 3/8-32 Main jets are also 1/4-32, and there are taps on EBAY for 1/4-32. Sal |
11-15-2022, 06:42 AM | #3 |
Re: Holley 94
Thanks so much for the reply and info!!!
11-15-2022, 06:48 AM | #4 |
Re: Holley 94
This is the jet in question....
11-15-2022, 08:15 AM | #5 |
Re: Holley 94
The idle tube for the 94 has fine thread 1/4-32. The Stromberg idle tube has the same appearance but with a courser 1/4-24 thread.
11-15-2022, 02:34 PM | #6 |
Re: Holley 94
11-15-2022, 03:01 PM | #7 |
Re: Holley 94
Would it be worth explaining what you are trying to do?
Some pictures might help. |
11-16-2022, 11:39 AM | #8 |
Re: Holley 94
Unsuccessful finding replacement main jet for alloy, Model A updraft carb by Simmons. I've attached a photo. Holley 94 jet looked similar, but wrong thread size; needs to be 3/8-24.
11-16-2022, 06:47 PM | #9 | |
Re: Holley 94
You could go to this Forum online and ask if anyone can help. Sal https://forums.aaca.org/topic/206897...-ford-model-a/ |
