01-13-2019, 03:03 PM | #1 |
front spring
looks like i could use a new spring. the one i have is rusty, has a broken leaf, and the 4 or 5 longest leaves have worn into the leaf below. has anybody used a spring from Mike's Affordable or Snyder's? How did it work?
thanks, Dick |
01-13-2019, 04:48 PM | #2 |
Re: front spring
I recently installed a new front spring from Travis M. Cook, www.a-springs.com, and couldn't be happier with the experience and the result. It completely solved a persistent oversteer condition in my cabriolet that had plagued me for years, as well as providing me with an improvement in ride quality. His product is excellent, as is his customer service.
01-13-2019, 05:09 PM | #3 |
Re: front spring
When we put a new spring on the front of our 29 Sport Coupe it made a big difference.
My only recommendation is to spend a little extra and get a USA made spring. While you have the front end down. Check the other ware points. Enjoy. |
01-13-2019, 05:21 PM | #4 |
Re: front spring
Also have one from a springs. Great people to work with.
01-13-2019, 06:32 PM | #5 |
Re: front spring
I also used A Springs. You get brass shakel bushings with the spring as well.
01-14-2019, 04:20 PM | #6 |
Re: front spring
I bought front and rear springs from him for my 31' Town Sedan. Love the ride. I coated both sides of the disassembled springs with two coats of Slip-Plate. Then once assembled put a coat of satin black Rustoleum over the entire thing.
1931 Murray Town Sedan. Black body with Apple Green pin stripe. 1923 Model T Touring with electric start. Low radiator Cincinnati, Ohio Last edited by jwilliams81; 01-15-2019 at 08:37 AM. |
01-14-2019, 08:32 PM | #7 |
Re: front spring
Travis Cook at A-Springs is the only way to go. Quality spring and great customer service.
