Old 12-30-2010, 10:19 PM   #1
Mountain Dew
Mountain Dew's Avatar
Default Pto
Did any AA models have a Power Take Off?
Mountain Dew is offline   Reply With Quote
Old 12-30-2010, 10:33 PM   #2
1930artdeco
1930artdeco's Avatar
Default Re: Pto
I believe they did for the bed-as I saw one at the Vancouver show. The 4speed tranny I have has a block off plate where one attaches.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 12-30-2010, 10:39 PM   #3
JD Miller
Default Re: Pto
Of course they had a PTO available. You must have seen pictures of dump trucks, fire trucks, and cement mixers, to name a few. How do you think they got power to run those type installations?
JD Miller is offline   Reply With Quote
Old 12-31-2010, 04:55 AM   #4
sturgis 39
Default Re: Pto
Not all trucks had the four speed transmissions. The early trucks had the regular car transmission with an under drive auxiliary transmission.These trucks did not have a power take off. Some of the old dump boxes were dumped by hand using cables, cog gears and a hand crank or a combination of all three. This was when truck drivers were truck drivers. They did not dress like drug store cowboys. You know why cowboys wear tennis shoes? They do not want to be identified as truck drivers. That is an old joke.
What is kind of interesting is hydraulics on construction equipment did not start until the late fifties or early sixties. Everything was cable driven from shovels to dozers. I had a project where we had to dig a trench and install a pipeline. The owner then wanted to lay a parallel line. They thought my price was too high and they would dig the trench with their own equipment. They had an old Brycirus (sp) Erie cable backhole. It took them about four days to dig the trench and we dug ours in a day with a John Deere 510. I watched the operator and he worked his butt off. He had all kind of levers to pull and all kind of pedals to step on.
Old road grader blades were all mechanically driven with gears and shafts.
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED
Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread.
sturgis 39 is offline   Reply With Quote
Old 12-31-2010, 06:36 AM   #5
Bruce of MN
Bruce of MN's Avatar
Default Re: Pto
You made me remember my Dad telling me he had operated a grader before WW2, probably in the CCC. I wish I had enough sense to ask him about all that stuff when I could. Luckily, I still remember driving up Pikes Peak in our '31 Coupe in '55 or so.
Bruce of MN is offline   Reply With Quote
Old 12-31-2010, 10:53 AM   #6
Peter J
Peter J's Avatar
Default Re: Pto
My son in law's 29 AA dumptruck has a PTO plate under the trans instead of the side which I hear is rare. I'm currently looking for a replacement for him. It's a 3 speed with a Ruxtel axle.
Peter J is offline   Reply With Quote
Old 12-31-2010, 11:05 AM   #7
sturgis 39
Default Re: Pto
I would like to see some pictures of that transmission and the rest of the truck when you get time.
Thanks
Old 12-31-2010, 11:41 AM   #8
Bob C
Default Re: Pto
Here is a picture of a AA 3-speed with a PTO on the dual-hi.
This came from the AA site.
Old 12-31-2010, 07:35 PM   #9
sturgis 39
Default Re: Pto
Originally Posted by bob c View Post
here is a picture of a aa 3-speed with a pto on the dual-hi.
This came from the aa site.
thanks for the picture. I have a couple under drive transmissions. I will have to look at the bottom and see if they have a pto plate. I do not think they have one.
Thanks
Old 01-01-2011, 12:55 AM   #10
Peter J
Peter J's Avatar
Default Re: Pto
I think I got this uploaded, I don't know. Anyway, I'll find that photo of the pto and put it on also.
Pete
Old 01-01-2011, 09:44 AM   #11
Peter J
Peter J's Avatar
Default Re: Pto
This is the pto from my brother-in-laws AA dump. As I recall, the pto was a chain drive to the hydraulic pump for the ram. I'm looking for one of these for his truck if anyone has any clues.
Old 01-01-2011, 05:14 PM   #12
sturgis 39
Default Re: Pto
Thanks for the drawings. The under drive transmissions I have look the same and shifts the same. Your axulliary is an over drive? I noticed you called it a dual over drive. I am just wondering if one of mine could be an overdrive.
Thanks
THAT IS A GOOD LOOKING TRUCK. I LIKE THE CRANES THEY MAKE THERE TOO.
Old 01-01-2011, 05:20 PM   #13
Bob-A
Bob-A's Avatar
Default Re: Pto
Love those wire wheeled '28 AA's.........
Bob-A is offline   Reply With Quote
Old 01-02-2011, 10:08 AM   #14
Ronnie Lawson
Ronnie Lawson's Avatar
Default Re: Pto
Are the pictures an air compressor for the model a transmission?
Ronnie Lawson is offline   Reply With Quote
