10-25-2020, 12:30 PM | #1 |
Fan clearance issue
Have my 8BA with Super Dual intake back in my '40. Am now working on the fan issue. I have tried what I thought was a '42-'48 fan assembly, but turned out to be a '49 assembly which has an 18" fan. Definitely no clearance with the upper hoses !! I have a '42-'48 oil hub assembly, but no fan. Has anyone out there run a '42-'46 assembly with stock 16" fan and had clearance with the upper hoses with a 8BA in a '40? Does any know where I could purchase a replacement fan ? What are other options, if any ? An electric fan is really the last resort. I do know about the crank mounted option that other members here done.
10-25-2020, 12:52 PM | #2 |
Re: Fan clearance issue
This will help. Be sure to read all the links. Also Bob Drake sells 8BA fan hubs.
https://www.fordbarn.com/forum/showt...ance+1936+ford |
10-25-2020, 01:02 PM | #3 |
You have obviously found out that using an 8BA-type engine in these earlier cars always seems to present a REAL problem when trying to come-up with a solution for a MECHANICAL fan, and of course, even thinking about settling for an ELECTRIC fan to 'band-aid' the problem is about as cool as taking your sister to the prom! It's a given that you need to lower that fan to clear the upper hoses in a '41 or earlier Ford. Fellow FordBarner "Heard" had a similar problem with an 8BA in his little '36 3-window coupe. We designed and built (from scratch) the unit seen in the picture below which LOWERS the fan's location with reference to the upper hoses. Click the link below for a better description and more pictures. DD https://www.fordbarn.com/forum/showt...08#post1869208 ......... |
10-25-2020, 03:11 PM | #4 |
Here's a few more photos that may help you design a solution. I made the alum. fan pulley back in 2014. BOB DRAKE now sells them at a fair price. Go to his web site.
Keep in mind each situation is different. My 8BA is in a 40 using wide belt 8RT water pumps and a Walker radiator. Make a mock up of your parts before you start taking your car apart. My fan is 16 in. There are folks who have other ways of doing this. Good luck. Last edited by 19Fordy; 10-25-2020 at 03:16 PM. |
10-25-2020, 09:08 PM | #5 |
19forty, what crankshaft pulley are you using?
10-26-2020, 09:36 AM | #6 |
Here's one on Ebay with an outrageous price. https://www.ebay.com/itm/1948-1953-F...UAAOSwqQpeRZvb |
10-26-2020, 11:01 AM | #7 |
Thanks for all the good info. Now we can start working this problem out. One other question, where do find a fan that fits the original bolt pattern or the Drake hub ?
10-26-2020, 11:47 AM | #8 | |
If you decide to use an original fan blade make sure it has no microscopic cracks of flaws that may cause it to work harden and fly apart. I had that happen ONCE! It went thru the hood and into the radiator. https://www.bobdrake.com/FordItem.aspx?Item=21A-8600-K Last edited by 19Fordy; 10-26-2020 at 11:54 AM. |
10-26-2020, 08:16 PM | #9 |
19Fordy,
What is the approximate dimension between the original fan pulley location and where you presently have it located ? |
10-26-2020, 11:04 AM | #10 | |
10-26-2020, 06:51 AM | #11 |
Nice solutions!
10-26-2020, 11:38 AM | #12 |
40cpe; Keep doing research. I know I have seen posts where folks also used the narrow belt pulleys found on stock (two narrow belts) 8BA engines and 51 Merc engines.
10-27-2020, 06:52 AM | #13 |
19fordy has a great idea; have your machinist buddy make a new set up that will have everything fit perfect and new bearing and aluminum pulley which can be machined to hold modern fans.
10-27-2020, 08:39 AM | #14 |
fortyfords makes a good point. If you use a fan spacer you can have it machined so that it has the fan blade holes in the location you need AND a hub centric "button" can be machined on that spacer. You may want to have a couple of sets of fan blade holes drilled into the spacer as there is plenty of room to do it. Easy to do once it's on the rotary table. Make several fan spacers of varying thickness "just in case".
The 6 inch dia. piece of 6061 Aluminum needed to make the fan pulley, etc. is not cheap if you buy it retail. Drakes pulley is a good deal for the money. Last edited by 19Fordy; 10-27-2020 at 09:33 AM. |
