08-12-2021, 09:14 AM | #1 |
Anto Sway Bar, Rear Shocks on 1939 Deluxe Vert
Planning on installing this kit bought from B Drake this weekend. On my 39 right now, are the remnants from what we think is a Western Auto Store rear shocks which look very similar to the shock mounts included in this kit. It is located on the left rear backing plate and I have not removed it to see if the bolt holes line up. Dang I hope they do!
Both shocks have been removed as well as the shock mount from the right backing plate. The upper bolt is still in the backing plate but the lower bolt is gone and has been replaced by a short bolt. In the cross frame member there are holes on each side which look like they would support the upper shock mount pegs. While replacing all of the brake shoes, master cylinder and brake lines it appears obvious that a great trauma occurred some time in the past on the right rear wheel. Like maybe it hit a curb at high speed and removed the lower backing plate shock mount. I say this because the brake drum appears to have been replaced as it shows very little wear compared to the other drums which are worn past tolerance for turning. It also has a brand new "not-rusted" brake line running to it where all the other brake lines are very rusted looking and have been replaced. Anyone who has made this modification successfully and has advice, this rookie will appreciate it PS Many have advised to replace with the original Houdaille Shocks but I choose to go this way since there are tube type piston shocks already on the front wheels. Last edited by Ramblin Reck; 08-12-2021 at 09:34 AM. Reason: Correct my error about new bolt! It is important |
08-12-2021, 09:24 AM | #2 |
Re: Anto Sway Bar, Rear Shocks on 1939 Deluxe Vert
The Drake rear sway bar, shock kit is the single best modification you can make on an early Ford.
That's my opinion, and I'm sticking with it. The tailpipe(s) will need to be modified. |
08-12-2021, 09:35 AM | #3 |
Roger That!
08-12-2021, 10:36 AM | #4 |
When I converted the Columbia under my '36 from an original Columbia to a '47-48 unit I utilized the Ford Panhard/sway bar and tube shocks. The conversion really improved the handling of the car at speed on the hiway.
It should be noted that the Ford Panhard bar has a dip in it to clear the right tail-pipe
Bill.... 36 5 win cpe |
08-12-2021, 11:54 AM | #5 |
Ramblin Reck, Please post some photos of what you are doing, if possible.
08-12-2021, 12:11 PM | #6 |
08-12-2021, 01:54 PM | #7 | |
I did use the CE bar at the front, but found the bar to large in diameter, making the ride to harsh. I exchanged the CE bar for a smaller diameter bar from a '50 Chevy (front). This proved to be a good mix, flat in the corners plus a decent ride. I also have read many articles about "handling & chassis & suspension theory". Last edited by 42merc; 08-12-2021 at 02:22 PM. |
08-14-2021, 01:10 PM | #8 |
From my experience I have found that generally people confuse Sway Bars/Panhard bars with body roll bars.
The bar that Ford added to the front end of the DeLux '40 Fords is actually a bar to control body roll-up on turns. The bar that Ford installed on the rear of the '47-48 Ford/Merc's is a Panhard tracking bar to keep the suspension aligned with the chassis, ie; sway bar. On the pre-42 model Fords, Ford used very short shackle bars, therefore there is not much need for a sway/track bar. The 42-48 had longer shackles, cars that had long shackles for lowering purposes could experience better control on turns with a sway/track bar. My '36 has later model springs due to the '48 rear axle and '41 front axle with later model shackle bushings and shackles, therefore, a Panhard Bar is very helpful.
