Old 08-03-2020, 06:39 AM   #1
fundytides
fundytides's Avatar
Default Drive In Grease Fittings
I decided to change all of my grease fittings over to the modern style. There was a mix of original and modern on the car. I am having trouble with the new drive in fittings. I am trying to drive them in with a small socket on an extension and a hammer. They won't seem to go. Do I need to enlarge the holes a bit or just use a bigger hammer? Anyone else run into this?
fundytides is offline   Reply With Quote
Old 08-03-2020, 06:53 AM   #2
dpson
dpson's Avatar
Default Re: Drive In Grease Fittings
There's a special tool to drive in those fittings.
https://www.snydersantiqueauto.com/P...ESS-IN-FITTING
dpson is offline   Reply With Quote
Old 08-03-2020, 08:54 AM   #3
john charlton
john charlton's Avatar
You really do need the tool it works a treat .Do not enlarge any holes the fittings will most likely fall out after a while .
John jn sunny West Drayton London with daughter .
john charlton is offline   Reply With Quote
Old 08-03-2020, 12:45 PM   #4
Big hammer
Sorry I'am to far away! Get the tool that's made for driving them in, DONT drill the holes larger, I've made the fittings smaller.
get a bigger hammer tap done
Old 08-03-2020, 12:50 PM   #5
Curtis in MA
How hard do you have to hit it?
I have the tool but never got any in.
Curtis in MA is offline   Reply With Quote
Old 08-03-2020, 12:50 PM   #6
shew01
shew01's Avatar
I bought that tool. I don’t see where it helps much, or at all. The tool works about the same as pounding on a small socket that has a socket extension inserted into it. The replacement zerks appear to be too big for some of the holes (not all of the holes) that are already drilled in the car. The threaded zerks in the zerk kit that I bought from one of the vendors work fine.
shew01 is offline   Reply With Quote
Old 08-03-2020, 04:26 PM   #7
john in illinois
john in illinois's Avatar
I bought some drive in modern fittings and they were way too large for my 30 Tudor. The ones I previously installed just took a straight in couple of taps. These I couldnt get started.
John
Welcome each day
john in illinois is offline   Reply With Quote
