09-10-2019, 07:02 AM | #1 |
Single wide pulley for 32 - cut off fan flange?
Hi,
I have a 32 on a 59A with a single wide pulley but it is leaking. Can the 91A-6312 Single Sheave Pulley (wide belt) with a fan mount flange be modified to work by cutting off part of the hub and removing the fan flange part or perhaps 21A-6312 Dual Sheave Pulley (wide belt) - Pressed Steel - Wide Spacing work too if cut down? What I really need is a good single wide part 81C-6312A though. Thanks, Glenn Last edited by glennpm; 09-10-2019 at 07:34 AM. Reason: Added part nos and othe option |
09-10-2019, 07:19 AM | #2 |
Re: Single wide pulley for 32 - cut off fan flange?
I have NOS
09-10-2019, 07:36 AM | #3 |
Hi KiWinUS,
Which one do you have please, the single pulley 81C-6312A? Thanks |
09-10-2019, 09:39 AM | #4 |
That’s exactly what I have. Cheers
09-10-2019, 12:05 PM | #5 |
Thanks Tony! |
