Old 11-09-2018, 12:04 PM   #1
HOTROD_WILLIE
HOTROD_WILLIE's Avatar
Default Rex Temperature Gauge Fitting
I have old Rex temperature gauge. I need fitting to attach to Model A Ford block. Thanks for the help.
HOTROD_WILLIE is offline   Reply With Quote
Old 11-09-2018, 12:10 PM   #2
HOTROD_WILLIE
Default Re: Rex Temperature Gauge Fitting
Here is the fitting end.
Old 11-09-2018, 12:19 PM   #3
Flathead
Flathead's Avatar
Probably could use a Stewart Warner adapter fitting, easier to find at a parts store. Use a radiator hose nipple with a pipe threaded hole.
Flathead is offline   Reply With Quote
Old 11-09-2018, 12:29 PM   #4
HOTROD_WILLIE
Already try that. Thanks
Old 11-09-2018, 03:00 PM   #5
talwrench
If my memory is not failing i think I found the matching fitting at a NAPA store
talwrench is offline   Reply With Quote
Old 11-09-2018, 04:16 PM   #6
Chris Haynes
Chris Haynes's Avatar
Most likely it attaches to a water outlet and not the block. I bout my outlet from Snyder's. https://www.snydersantiqueauto.com/drilled-water-outlet
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
