10-16-2016, 08:08 PM | #1 |
Are all 30/31 headlight bars the same?
Hi Dear Members:
Can anyone confirm if all the 30/31 headlight bar were the same? Thanks for your help!
Henry' s 31 |
10-16-2016, 08:40 PM | #2 |
Re: Are all 30/31 headlight bars the same?
NO they are not, but I'm in Canada so maybe my info only applies to Canadian Model As. There is a bar that has a stamped steel center section. I have two friends who traded bars so they would both be correct.The stamped one was for the 31 slant windshield.
10-16-2016, 08:44 PM | #3 |
Kinda like what Ian just said. There is a stamped steel one out there but the thing is they all fit every 30 31 model whether they be the stamped steel or the solid bar style.
10-16-2016, 08:52 PM | #4 |
A 28-29 headlight bar will fit a 30-31, but won't look right.
10-16-2016, 10:36 PM | #5 |
The stamped bars are also prone to breakage. A good, unrepaired original is hard to find.
10-16-2016, 11:37 PM | #6 |
Forged end bar used from the introduction of the 1930 bodies through April 1930 and from September 1930 through the end of production.
10-17-2016, 07:40 AM | #7 |
Mike is correct, follow his direction...
10-17-2016, 08:04 AM | #8 |
Carl,
Is that like a face lift, GONE BAD? Saw a '30 Coupe, with '29 Splash Shields & Fenders---"Did they fit OK"?----"Don't know, it was like that when I stole it" Bill W.
10-17-2016, 09:29 AM | #9 |
Thank you all for your help and information. As always you are very helpful.
Henry' s 31 |
10-17-2016, 11:56 AM | #10 |
My light bar on my '30 ccpu has two holes centered from the mid point of the radiator which go through the bar itself. The two holes face forward and not downward. I am assuming that they may be there for license plate holders to be attached, but that is just an assumption on my part. They seem too far for he average license plate mounting of today. This is the bar that came on the pickup when I purchased it and I have no idea if it is original or not to the truck. Am I correct as to the purpose of those two holes or is this a light bar adapted on it from some other Model A?
I never had a front license plate on any of the previous Model A's I have owned and never remember noticing them or even checking for holes like these on my current pickup. I saw a fellow at Chickasha carrying around a light bar with the buckets attached, but I forgot to look it over to see if it had the same holes in it. |
10-17-2016, 12:21 PM | #11 |
You should be able to see the difference here: The first picture is with the '29 light bar, the second one is with the '31 light bar. The earlier bar puts the head lights a couple inches higher on the truck.
10-17-2016, 01:23 PM | #12 |
If you have a round light bar with holes to mount the license plates, then some owner drilled them.
In the old days license plates with long numbers were often long plates with wider spaced mounting holes. That's one reason I'd like to find a 3 or 4 digit plate, rather than a 5 or 6 digit. |
10-17-2016, 01:34 PM | #13 |
Yes, in holding up a new stock license plate, the mounting holes are a good 1-1 1/2" further apart than the holes on the plate are.
I have a new custom license plate coming and I'll end up having to figure a way to mount it other than using these two pre-drilled holes. I want to secure it well enough that some 5 finger discount person won't just pull it off with a slight tug. Time to break out the 50 million megawatt, but only 1 amp, Miller welder, huh? The lights may soon dim in my neighborhood. It's alive! It's alive! :-) Thanks for the info. |
10-17-2016, 01:41 PM | #14 |
x2.
10-17-2016, 01:57 PM | #15 | |
A few years ago I bought a nice bar at Hershey with holes exactly as you describe, and a few days later I realized that they were not original.
I filled them in (with metal, not bondo) and painted the bar, and it has been on my car ever since. Doug Quote:
My '31 S/W sedan project:http://31ford.dougbraun.com My restoration diary: http://dougbraun.com/blog |
10-17-2016, 05:34 PM | #16 |
Holes would have been impractical for production, as license size varied a good deal between states. That's why stamped one had slots and the bar had the movable clamps.
