10-10-2016, 11:42 AM | #1 |
Are 1930 Fenders the same on 1930/31 Tudor and Roadsters
Hi Fellow Barn Members:
Can someone out there confirm if the fenders are the same on a 30/31 Tudor and Roadster. I know the splash aprons were different for a 1930 and a 1931. Appreciate your help so I purchase the correct ones.
Henry' s 31 |
10-10-2016, 11:59 AM | #2 |
Re: Are 1930 Fenders the same on 1930/31 Tudor and Roadsters
Fenders for 30-31 are the same basically...BUT
Fenders for the two piece apron will not have bolt holes as the extra section was welded to a lip that is usually shorter then found on the 31 fenders that were bolted. Also keep in mind there are 2 styles of fenders. One has the crease running further back causing a bit more of a curve as you get to the running board. Kind of hard to see unless you are looking at the 2 different fenders side by side. I am told there is a known original untouched car with one of each type on it. |
10-10-2016, 12:18 PM | #3 |
Just to be clear you are talking about front fenders and not the rear fenders ?
10-10-2016, 01:01 PM | #4 |
Hi Bill:
I am actually talking about fron and rear. I purchased a matching numbers chassis with a title for a 1930 Station Wagon. I was told the 30 Tudor fenders front and back would fit. I have an opportunity to purchase front and rear fenders for a 31 roadster and was trying to find out if they would fit.
Henry' s 31 |
10-10-2016, 01:22 PM | #5 |
Rears are very different between coupes/roadster and tudors
Blackwall Panthers Nor Cal chapter |
10-11-2016, 12:30 AM | #6 |
The first is 28 29 coupe and roadster next is the 28-29 sedan third is the 30-31 coupe and roadster next the 30-31 sedan and last is that triangle shaped on the all sedan fenders
10-11-2016, 08:11 AM | #7 |
As always I appreciate the information provided. This website is surely a great asset to the Model A Hobby. Thanks to all of you that provided great information.
Henry' s 31 |
Thread Tools | |
Display Modes | |
