04-04-2012, 06:20 PM | #1 |
Inner headlight ring
Has anyone replaced the inner rings? They were spot welded originally, but this looks like it would be hard to do. Has anyone tried epoxy?
04-04-2012, 06:32 PM | #2 |
Re: Inner headlight ring
drill small holes in the ring where you want the welds. MIG or TIG the mating surfaces starting on the base through the holes and up through the ring. Grind it flat if you build it up too far.
Are you related to Bruce and Jean? |
04-04-2012, 09:22 PM | #3 |
Thanks Pat, I will try that.
I do have a cousin in Santa Ana that is Donna Jean Ariss, but that was her maiden name. Her husband died a couple of years ago. |
04-05-2012, 07:35 AM | #4 |
