05-21-2014, 02:01 PM | #1 |
1940 ford temp sender
Guys, are there a tempature sending unit that will replace the high price org. Unit in the flathead? Anyone have a NAPA part no. My is the single terminal one. Thanks to everyone.
05-21-2014, 02:19 PM | #2 |
Re: 1940 ford temp sender
Ebay motors has them quite often. There's a couple on there now.
http://www.ebay.com/sch/sis.html?_nk...d=251198101941 Last edited by 19Fordy; 05-21-2014 at 02:43 PM. |
05-21-2014, 02:36 PM | #3 |
Try one of the Ford restoration parts specialist. Examples below
http://cgfordparts.com http://www.concoursparts.com/
Steve '55 Sunliner - 292 V8, 3 speed man. w/ OD ČKMAA - Český klub majitelů amerických automobilů |
05-21-2014, 07:36 PM | #4 |
Thanks Guys, I don't want the org. Unit , I want to know if there is one that will replaced it. One that will work from another motor. Some say a '75 ford truck would interchange . Anyone know for sure or have aNAPA part number. I have change to 12 volts , i have a voltage regulator on the cluster.
05-21-2014, 10:46 PM | #5 |
I use a '75 ford sender but I also have the gauge that goes with that sender. I doubt that sender would match a stock gauge. You can get a '75-6 sender from autozone or advance auto and try it for about $15. If you can find a gauge/sender off a '75 Ford truck and you already have 12V, you can disassemble the stock gauge, replace the stock movement with the '75 movements ( it will fit exactly in the stock gauge case), install the newer sender and you're ready to go. newer gauge/sender with stock look.
05-22-2014, 01:21 AM | #6 |
http://www.hansenwebdesign.com/truck...nstruments.pdf |
05-22-2014, 08:30 AM | #7 | |
Ford kept using basically the same 6v gauge from I believe 57 to 78 in large trucks. The 40 gauge face fits it perfectly and it fits as is in the 40 housing. It is completely undetectable except for one thing …. at rest it is on cold The advantage is You can walk in any auto parts store and get the single sender that runs it. |
05-22-2014, 11:10 AM | #8 |
BillM
I think that you have it backwards, the single terminal sending unit is the one that changes the reading on the gauge with changes in temperature, the double contact unit is just an over temperature switch.
TomO |
05-22-2014, 12:59 PM | #9 |
The link I posted didn't work; try this one:
http://www.hansenwebdesign.com/truck...nstruments.pdf In that PDF it shows the temperature sender with only one terminal; with the case grounded. However in the Ford V8 system the two terminal sender is grounded by the normally closed switch in the single contact "sender". This arrangement provided a backup in case the side of the engine with the single sender went over temp. There has been postings by others who have copies of the Ford manuals that details this. |
05-22-2014, 01:10 PM | #10 |
Just to clear up any confusion, here is the explanation with diagram of how the two temperature senders work together. Indeed, the two contact sender is just a flow through for the current to the single contact sender that actually varies the current for the gauge. The two contact sender is just a "circuit breaker" that opens if over temp.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 05-22-2014 at 01:33 PM. |
05-22-2014, 04:33 PM | #11 |
Thanks Guys, I had a '75 ford f600 junked truck, I took gauge out and change face from '40 gauge put '75 truck sender in fix my problem, worked good. Thanks to every one. Have a Blessed day!
05-22-2014, 07:14 PM | #12 |
That's great Brooks … very easy swap except for taking the cluster in and out.
So everyone else will know …. this is what they look like I believe this basic cluster was used from 57 to 61 in everything pickup and truck Then it was continued in use all the way to 1978 in bigger trucks - f 500 - 600 and cabovers / C series trucks. 1.Temp - oil - and fuel gauges fit directly in the 40 cluster housing … no mods what so ever 2.The orig or repo 40 gauge faces simply crimps on and off in place of the black ones in the photo. Id bet these gauges also fit in later fords also. I’ve saved a bunch of them from trucks that got scrapped …. The steering column in the same trucks are very useful also …. oldtime looking but with a turn switch |
05-22-2014, 08:00 PM | #13 |
You are correct; and thanks Old Henry for the picture out of the manual, I will definitely copy and save that.
