12-21-2019, 08:48 PM | #1 |
Removing lock cylinder from 1934 Ford trunk handle
Can key lock cylinder be taken out 34 Ford trunk handle without a key. If so what is the trick, as I am not having any luck. Thanks, Jerry
12-22-2019, 01:52 AM | #2 |
Re: Removing lock cylinder from 1934 Ford trunk handle
NO it can't.There is a hole at the edge of the handle and a spring loaded pin(on the lock cyl) in it .The key has to be turned 90 degrees to be able to depress it ,then the lock cyl can be removed.You need a key or someone that can pick the lock.32Phil on this site can assist you.
12-22-2019, 06:51 AM | #3 |
The cylinder can be drilled out destroying the cylinder, without damage to the handle.
12-22-2019, 10:24 AM | #4 |
32Phil has not been on the HAMB since Nov 3. I tried to contact him a month ago and no response. I hope he is OK.
12-23-2019, 10:46 AM | #5 |
Thank You for the concern Andy. I made the mistake of buying a new computer..... It's been a wild ride since...... to say the least !!! I will be leaving for Florida in early January sooooo Early Ford Lock & Key service is on hold till April. The good news is everyone's locks/keys etc. have been mailed out. I will still be available for phone questions/help on my cell 845 551 5132. Enjoy the Holidays...……... see ya at the car shows in Florida !!! Phil
Early Ford Lock & Key Service http://www.fordbarn.com/forum/showthread.php?t=46583 |
