06-10-2019, 09:35 AM | #1 |
Preferred Speed
With basily stock '31 Pickup, 3.78 rear end, what would your preferred crusing speeds be should you consider while on a 1,200 mile trip, time isn't important.
There's this (60th year) high-school reunion I want to crash! Thanks |
06-10-2019, 10:16 AM | #2 |
Re: Preferred Speed
Your stock Model A should be able to cruise all day at 45-50 MPH.
When estimating how many miles you will cover in a day, I use 40 MPH (to allow for frequent comfort breaks and to be able to stop and check out interesting things along the way). So 6 hours at 40 MPH is 240 miles in a day, and in 5 days you cover 1200 miles. I have found 240 miles to be my limit when you are going to stack multiple days up in a row; others go further. You can do more if it's a one-day drive (and then you recover the next day) or if you have multiple drivers. The pickup is kind of cramped, not the most comfortable seat. You will want to get out and move the legs pretty often. And taking the time to stop and check things out is part of the fun!
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" |
06-10-2019, 10:23 AM | #3 |
Re: Preferred Speed
I agree with Jim.
06-10-2019, 10:30 AM | #4 |
Re: Preferred Speed
I prefer to run 50 MPH where the road permits .
06-10-2019, 11:47 AM | #5 |
Re: Preferred Speed
For comfort I found and an angled vinyl covered 1 place cushion that I sit on. Helps a lot since my bottom seat cushion angles downward towards the back of the cab, and my seat springs/cushion are marginal at best. It gives me extra cush, and raises me up in the cab further. Additionally I have a cushion for lumbar support, allows me to sit in more of an upright position instead of hunching over/toward the steering wheel.
06-10-2019, 02:07 PM | #6 |
Re: Preferred Speed
Jim That sounds like 3 weeks on the road, in a Pickup, if all went as expected. I've studied a route, that bridge going over the Mississippi River in Baton Rouge might be one problem thinking about--it's rather steep. Getting there more important than getting back -- these reunions are once every 5 years, this very well could be my last one to try using the Pickup -- I do have flight benefits from my old Company-- Wife said absolutely would not come with me if it's the Pickup -- prefers the Boeing 747 ?? |
06-10-2019, 04:30 PM | #7 |
Re: Preferred Speed
If you go out for a ride what speeds do you end up driving, how well does it drive up near 60
I find my car creeping up into the low to mid 50s if traffic is moving that speed, did 65 all day on the pa turnpike and the car felt secure and comfortable, there is a bit of a hill going into Ohio, I was slowing down a lot, started to worry, then started passing cars going slower--- did get some looks of surprise |
06-10-2019, 04:30 PM | #8 |
Re: Preferred Speed
You may be looking at the bridge where I-10 goes over the Mississippi River. Go north a short distance and use the US-190 route. In fact, I'd stay off of I-10 whenever possible.
Look at the route called the Old Spanish Trail. It started in St. Augustine, FL, and went to San Diego, CA. It goes goes through Houston and San Antonio. http://www.drivetheost.com/history.html http://www.oldspanishtrailcentennial.com/Home.html I like to stay on US Highways. They are safer for you to run at 45-50 MPH, and they are very scenic. Lots of cute small towns to go through. The roads were made for the Model T and Model A to run on, you won't have a problem.
06-10-2019, 06:04 PM | #9 |
Re: Preferred Speed
You didn’t say if you have traveled with it much before on the Hiway, but I agree with Jim that about 250 miles/day will tire you out, especially with the limited room of a pickup. There is also little room to carry anything else inside, such as luggage. Most stock, decent running A’s seem to be comfortable 45-50 mph for cruising. Cooling system, brakes, and electrical all need to be in good shape.
06-10-2019, 06:54 PM | #10 |
Re: Preferred Speed
I've not traveled on major hiways (in S. Fla), and 40 mph has been as fast as I gone in the '31. Since this event is first of June, 2020, I've plenty of time to plan/decide. When I graduated (1960) - I drove a '29 Business Coup until '62 when I joined the AirForce. The Pickup I've had for almost two years and have replaced brakes, pins, tires and installed an alternator.
The reunion is just South of Monroe(Louisiana), Jonesboro to be exact-- it just seems 50 mph is to fast for my equipment. My thoughts are, also, have it shipped to the Family Farm and drive it back on the return. That way I'm assured getting in on time. Personelly I'm not sure 50 mph is doable and it would be entire solo. Anyway, lived in NewOrleans 20 years (1966/86)-need to by-pass that place, but it would be nice to re-visit some of those speed-traps again!! Thanks for the maps Jim. |
06-10-2019, 07:07 PM | #11 | |
Re: Preferred Speed
06-10-2019, 08:26 PM | #12 |
Re: Preferred Speed
An overdrive unit would be perfect.
06-10-2019, 09:45 PM | #13 |
Re: Preferred Speed
I drove a 29 pickup from close to Sf to Portland with an overnight in Coos Bay. The return was inland and straight through, fourteen hours. Speed was usually about 60 mph with a B/W overdrive 36%, and an overhead valve head.
Going the other direction, drove to Chula Vista via Hwy 1 and back on 101. Both 14 hr. days. Wouldn't do any of the above again for a free car. But drove to Tx and back in a roadster with 26% Mitchell and driving about 250 per day was very easy on me except for an electrical problem that we didn't solve until four years later. Loose wire at the alternator. So stick with the 250 mile limits and follow the advice of adding an O/D. You will thoroughly enjoy the trip and have memories that the airport can't provide. Wife rode home with me from TX and even she talks about it favorably most times. |
06-11-2019, 06:37 AM | #14 |
Re: Preferred Speed
What's probable missing is Confidence in the Pickup -- thanks everyone
06-11-2019, 08:08 AM | #15 |
Re: Preferred Speed
Maybe start taking some longer and longer trips and see if both you and the truck are up for it.
06-11-2019, 11:04 AM | #16 |
Re: Preferred Speed
Jim Cannon is correct. My car's sweet spot is 45mph.
1928 Niagara Blue Phaeton 1972 Olds 442 Convertible 1979 MGB -Life's Too Short To Drive Boring Cars- |
06-11-2019, 02:50 PM | #17 |
Re: Preferred Speed
JMO Trailer it and enjoy the re-union ! ! !
Paul in CT |
06-11-2019, 03:28 PM | #18 |
Re: Preferred Speed
06-11-2019, 05:55 PM | #19 |
Re: Preferred Speed
Go for it.
45 MPH and take your time. Just take a MARC or MAFCA roster with you in case you need a little help along the way. A couple of years ago I did a trip of a little over 2000 miles. No problems and very enjoyable. Just take your time. My opinion, Chris W. |
06-12-2019, 12:31 AM | #20 |
Re: Preferred Speed
My A drove the best at 50 miles. I live in germany and my longest trip was 610 miles in two days at high (98) temperatures. Please do not trailer your car! The fun part is to drive it even if it hurts sometimes.
