Old 03-03-2021, 08:00 PM   #1
700rpm
700rpm's Avatar
Default Taillight fender hole.
I am going to add a RH taillight to my 1929 Tudor. Can someone please give me the correct diameter of the hole in the fender for the wiring? Also, if someone has a locator pattern for correct positioning, I could use that too.
Thanks.
Ray Horton, Portland, OR
Old 03-03-2021, 09:21 PM   #2
Stingray70
Stingray70's Avatar
Default Re: Taillight fender hole.
Could you just remove the left light and use a piece of paper to make a template relative to the fender edges? Use those hole sizes for the ones you are adding on the right.
1930 Standard Coupe
Stingray70 is offline   Reply With Quote
Old 03-04-2021, 08:01 AM   #3
Bob Bidonde
Bob Bidonde's Avatar
I caution you that the RH tail light brackets are not the opposite geometry of the original LH bracket, so do not transfer any location measurements from the LH side. Instead position the RH tail light with its bracket so it is visually of the same height and distance from the body as the LH light.
Bob Bidonde
Old 03-04-2021, 08:41 AM   #4
Big hammer
I measured twice and still the rh light didn't look right, it was close so I stepped back and adjusted the rh light to look right. I used a level and a long straight edge and taped the light to the fender moving it until it looked right.
Thank you Bob ! I thought it was just me being off.
get a bigger hammer tap done
Old 03-04-2021, 09:47 AM   #5
McMimmcs
McMimmcs's Avatar
I agree with the visual positioning and I suggest you use a helper just in case your eyes are playing tricks on you. After we agreed on location we taped it in place and stood back and had a look from different directions.
Old 03-04-2021, 10:24 AM   #6
KenBolton
I did make a paper template of the left fender holes positioning the paper edge with the outside lines of the fender. I so took a measurement from the fender bottom. When I moved it to the right fender I turned the template over so it would fit. Visually and dimensionally all was well.
KenBolton is offline   Reply With Quote
Old 03-04-2021, 10:38 AM   #7
JayJay
Good tip, Bob, thanks for this. I need to put a RH taillight on my Sedan. Engineer that I am, I would have done this analytically by transferring measurements. Looks like I get to enlist my bride as Visual QA on this one.
Any of you with original part numbers - are the RH taillight brackets the same across all the passenger car bodies (aftermarket suppliers seem to imply so)? Looking specifically for any cross-applications with 1930 Murray Town Sedan.
JayJay
JayJay
San Francisco Bay Area
1931 Briggs S/W Town Sedan
Old 03-04-2021, 10:56 AM   #8
700rpm
700rpm's Avatar
I want to avoid taking the LH light off.
Old 03-04-2021, 10:59 AM   #9
Ruth
The tail light brackets made by Vintique are not even close to being symmetrical. Even when you level them up they don't look right.
Don't use the fender hole position of the left light for the right light. I guarantee you will regret it.
I avoid Vintique products whenever I can.
Ruth
Old 03-04-2021, 04:23 PM   #10
700rpm
700rpm's Avatar
I got the bracket from Mike’s.
Old 03-04-2021, 08:42 PM   #11
700rpm
700rpm's Avatar
This is all good info, but to get back to my original post, all I really need is the diameter of the hole in the fender for the wiring. Surely someone has a 29 Tudor left fender without the taillight attached in their pile, or are restoring a 29 Tudor and can measure that hole? Please?
Old 03-05-2021, 03:20 PM   #12
Gary Kelley
I have a 31 Tudor rear fender here that I have been working on and it has a one inch hole for the wires.
Gary Kelley is offline   Reply With Quote
Old 03-05-2021, 05:06 PM   #13
700rpm
700rpm's Avatar
Thank you, Gary! That’s the info I need!
