Old 12-20-2020, 10:58 AM   #1
harleycontracter
Default 30/31 Roadster tack strip
Have a question. I need a tack strip for my 31. I have a 32 from a previous build . My body is still in pieces so I can't try it. Anyone know if it's close enough to modify to work. I'd rather use original parts. I'm gathering parts what I'll need. Txs
harleycontracter is offline   Reply With Quote
Old 12-20-2020, 11:03 AM   #2
Tinbasher
Tinbasher's Avatar
Default Re: 30/31 Roadster tack strip
What Tack strip are you looking for? Where does it go? I can't think of one on a 30 - 31 Roadster.
Tinbasher is offline   Reply With Quote
Old 12-20-2020, 12:05 PM   #3
harleycontracter
The wood strip that sits across the back that you fasten the top to
Old 12-21-2020, 10:47 PM   #4
sjhark
sjhark's Avatar
My 31 Deluxe Roadster came with a steel strip (red arrow) that sandwiched a rope-like material (yellow arrow) for a tack strip. I only add this as you mentioned wanting to use original parts, and as far as I know, this was original.
If earthworms had machine guns, we'd all be in trouble!
sjhark is offline   Reply With Quote
Old 12-22-2020, 01:38 AM   #5
Oldbluoval
Oldbluoval's Avatar
Sjhark is correct
32 not same
Oldbluoval is offline   Reply With Quote
