03-08-2016, 10:23 AM | #1 |
Horn rod length
Hi folks,
My 1929 Fordor did not have the horn rod when I bought it. So I don't know how long I need it to be, can anyone shed some light on this? I have a 7 tooth steering box with a splined hub, if that helps. Car was manufactured April of 1929. Thanks!
-Rob 1929 Fordor Leatherback |
03-08-2016, 10:42 AM | #2 |
Re: Horn rod length
There's only one length light switch rod for the '28-29 seven-tooth columns: 45 3/4". The part number and price for this item from Snyder's is A-3616-B at $69.95.
Marshall |
03-08-2016, 10:44 AM | #3 |
Re: Horn rod length
I've seen 45 listed for the 28-29, as well as the 45 3/4.
You've answered my question though, and the 45 3/4 will be what I get. Thanks!
03-08-2016, 11:00 AM | #4 |
Re: Horn rod length
The 45 inch horn rod is for the two tooth 1929 column. Is your a 7 tooth column or a 2 tooth column?
03-08-2016, 11:01 AM | #5 |
Re: Horn rod length
