09-08-2010, 06:42 PM | #1 |
Bad starter switch? Dead short in starter?
Just returned from a 370 mile weekend trip without skipping a beat in our '30 Cpe. Parked, unloaded car, went to move it into "her" garage - no go. Solid battery. Good connects. Hit the starter rod zip, zero - nada. Try the lights - with the solid battery charge the headlights drop out about 90 percent - barely lit. Bendix is not hung up?????
Time to try a switch pull first? Any input - I would be grateful. PS - I disconnect the battery every time I park it - totally disconnect it. Thanks - SHEC Last edited by SHEC; 09-09-2010 at 08:00 PM. |
09-08-2010, 07:49 PM | #2 |
Re: Bad starter switch? Dead short in starter?
Sounds like a short somewhere other than the starter. I hope you run a fuse. If not, disconect the battery ASAP.
03-22-2011, 06:20 PM | #3 |
Gents - turned out to be a weak cell in the battery!
Driving down the Ford Road again! SHEC |
03-22-2011, 10:04 PM | #4 |
Makes for an easy jump start if the Floater misbehaves, and you have double electrical security. As Justin Wilson, the famous Cajun chef was fond of remarking that as a Safety Engineer he liked suspender AND a belt. It is also nice if a fellow 6 volt car needs a jump or a replacement during a tour/show. 6 Volts are not really that expensive (except Optima), but they are often hard to find on a weekend with a show in town and Easter weekend when O'Reillys closes early!
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die! |
