Old 09-14-2021, 04:05 PM   #1
HenryCarl
Default '35 Ford Coupe tail light lamp
I bought a replacement lamp through Mac's, Vintique. It has a double
contact which my socket has. There are two nubs on the lamp, opposite
each other. One nub is closer to the bottom than the other. I cannot
get the lower nub aligned with the slot to turn and secure. Please see
my photos. Thanks.
File Type: jpg Screen Shot 2021-09-14 at 4.02.22 PM.jpg (19.9 KB, 223 views)
File Type: jpg Screen Shot 2021-09-14 at 4.01.59 PM.jpg (14.6 KB, 215 views)
File Type: jpg Screen Shot 2021-09-14 at 4.01.06 PM.jpg (9.6 KB, 213 views)
HenryCarl is offline   Reply With Quote
Old 09-14-2021, 04:54 PM   #2
petehoovie
petehoovie's Avatar
Default Re: '35 Ford Coupe tail light lamp
my photos. Thanks.
Old 09-14-2021, 05:18 PM   #3
lgndlt5
The bulb base and socket only goes together one direction please note the staggered height of the pins on the bulb base. Olso in the socket. Push down when those are aligned and turn bulb 1/4 turn to the right to lock in the bulb.
lgndlt5 is offline   Reply With Quote
Old 09-14-2021, 06:04 PM   #4
Brian
Brian's Avatar
Does your socket have equal depth slots?
Old 09-14-2021, 07:51 PM   #5
HenryCarl
The slots don't seem to be staggered. They just don't align with the nubs, While one nub has a slot, the other nub is too deep.
Old 09-14-2021, 08:01 PM   #6
HenryCarl
An nearly as I can determine, they are equal depth slots. The would explain why the buns don't fit. But the bulb from Vintique and Mac's are staggered. Se photo. That would explain why they don't fit. As I said, the slots seem to be equal depth...not 100% sure. But these are the bulbs on offer from Mac's.
Old 09-14-2021, 08:30 PM   #7
Brian
Brian's Avatar
What you can do is carefully file off the nub that's in the wrong place as a cowboy fix, a better solution is to buy another bulb with the nubs directly opposite each other. Then, all you've got to do is install the bulb correctly, so tailite is the dull glow, brakelite is the brite glow.
Old 09-14-2021, 09:11 PM   #8
rich b
rich b's Avatar
If I remember right; many stock sockets had even depth slots and the bulbs had even nubs and had "top" printed on the base. Think we even had 12v bulbs with even nubs in an old box at the truck shop.
Old 09-14-2021, 09:18 PM   #9
Lawson Cox
Lawson Cox's Avatar
You want an 1157 bulb.
Old 09-14-2021, 09:40 PM   #10
HenryCarl
All of you. This was my grandfather's car, and it's always been in the family. It sat garaged twice. From 1943 to 1968. Then 1969 to 2019. I work on it. It runs again. I'm not going to restore it, there are too many memories in it. There's quite a story. Thank you for all the info. I'll make it work right again because of you. OH. He bought the Ford new. A farmer's car.
Old 09-14-2021, 09:48 PM   #11
TomO
1157 bulb is not correct for a socket with even slots. the 1158 is the 6 volt tail/stop light bulb for 6V even slot socket. Try a local auto parts sore or Amazon
TomO
TomO is offline   Reply With Quote
Old 09-14-2021, 11:24 PM   #12
Don Rogers
Don Rogers's Avatar
6 volt bulbs from that era mostly had even pins, not staggered. See image
Don Rogers is offline   Reply With Quote
Old 09-15-2021, 12:14 AM   #13
deuce lover
deuce lover's Avatar
Here on EBAY
https://www.ebay.com/itm/33241419057...0AAOSw~ppeWu9I
Old 09-15-2021, 01:28 AM   #14
petehoovie
petehoovie's Avatar
Old 09-15-2021, 01:47 AM   #15
V8COOPMAN
V8COOPMAN's Avatar
Don Rogers is correct! 6v dual filament with EVEN pins is an 1158.
For a 12v dual filament with EVEN pins is an 1176.
Click Links Below __
T5 W/TORQUE TUBE
Old 09-15-2021, 09:04 AM   #16
farmertom
farmertom's Avatar
hey Henry Carl,once you get the correct bulb in socket you want brighter lights? mart here on the barn came up with using a little aluminum pie tin so i went to my grocery store and came away with a small package of renolds alum.cup cake very shiney liners remove the paper separater cut a hole in bottom just large enough for bulb base the are so light weight bulb will support.i have a '37 ford works great brighter tail lights! they fit perfectly in the tailight housing. Tom.
farmertom is offline   Reply With Quote
Old 09-15-2021, 12:31 PM   #17
Anteek29
Anteek29's Avatar
Great tip...thanks, Tom!
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 09-15-2021, 02:05 PM   #18
Detonator
Detonator's Avatar
Years ago I came across a tip on the Barn: paint the inside of your taillight buckets gloss WHITE. I've done it on a number of cars since. It works.
Seabright Hot Rods
Detonator is offline   Reply With Quote
Old 09-15-2021, 02:49 PM   #19
RalphM
RalphM's Avatar
Let’s see a picture of that beautiful 35!
RalphM is offline   Reply With Quote
Old 09-15-2021, 07:07 PM   #20
paul2748
paul2748's Avatar
Yes - paint the inside of the lamp white for brighter lights.
48 Ford Conv
56 Tbird
54 Ford Victoria
