Old 05-07-2013, 08:08 PM   #1
jfcrash
jfcrash's Avatar
Default Headlight Lens Retaining Clips
Ref 1935.....I have tried and tried to install the after market lens retaining clips I got from Mac's (p/n 48-13061-S) which hold the headlite lens in the trim ring...
Whats the secret?? I am afraid I will break the lens in the process, they seem to tall for the job..and don't match up to the one original that I still have.
Can someone offer a suggestion of how the got them to fit or know a source for ones that do fit??
Thanks, Jim
______________________________________________
jfc
I couldn't repair the brakes, so I adjusted the horn louder....
jfcrash is offline   Reply With Quote
Old 05-08-2013, 07:10 AM   #2
oldandtired
Default Re: Headlight Lens Retaining Clips
The aftermarket clips I have seen were like what you describe...taller than the OEM ones, making it a challenge to get them to work.
oldandtired is offline   Reply With Quote
Old 05-08-2013, 09:19 AM   #3
V12Bill
V12Bill's Avatar
I had to get originals and toss out the Mac's retainers on my 39 pickup.
V12Bill is offline   Reply With Quote
Old 05-08-2013, 06:12 PM   #4
dean333
dean333's Avatar
Send a message via Yahoo to dean333
I'm having the same issues replacing the sealed beams on my 36 with the original glass lenses. I'm going to take them with me to the next V8 club meeting, hopefully a meeting of the minds will help.
dean333 is offline   Reply With Quote
Old 05-08-2013, 06:19 PM   #5
dean333
dean333's Avatar
Oh, I was told clips were no longer available to hold sealed beams in. I got my car with duct tape holding the beams which led me to go back the the original lenses. I like the original look better anyway.. my point, after getting clips for the glass lenses I found they hold the sealed beams perfectly!!
Old 05-08-2013, 08:38 PM   #6
Gary C
Hi: I just used some new clips from Mac's on my 35. You have to stretch them out a bit, The ends fit into the lip of the bezel, and the middle part fits into the notch on the lens. The trick is to stretch them out so that they are not so deep. Hope this helps. Gary C
Gary C is offline   Reply With Quote
Old 05-08-2013, 10:33 PM   #7
jfcrash
jfcrash's Avatar
Earlier today, I did exactly as Gary has stated, modify the shape of these newer replacments by streaching them out which lowered thier profile and still maintain a snug fit.
I only distroyed two before I figured it out.............
Jim
jfc
Old 05-09-2013, 08:22 AM   #8
dean333
dean333's Avatar
At the top center of the clip where it comes to a point in a "V' shape.....does the "V" point down to the lens or face up?
Old 05-09-2013, 08:25 AM   #9
dean333
dean333's Avatar
.....actually more like an elongated "U" about 3/8" wide.
Old 05-09-2013, 09:06 AM   #10
jfcrash
jfcrash's Avatar
It faces down toward the lens and rests in a notch area in the lens perimeter.
First picture is the new repro and the second is my original clip
Hopes this helps, Jim
jfc
Old 05-09-2013, 08:51 PM   #11
Shadetree
Shadetree's Avatar
My grandfather had a saying that I heard many times growing up. When something he was working on became stubborn he would say "The SOB (only he would say the real thing) that invented this should have died before he thought of it."
Forward 60 years or so.... I was working with these same retainers from Mac's for my `35 Cabriolet and my wife was helping me. After several attempts without me saying a word my wife said. "I agree with your grandfather." I broke up laughing so hard. We eventually got them installed. Hopefully the next owner will put them in the next time.
Son, you will never blow an engine up in high gear.
Shadetree is offline   Reply With Quote
Old 05-10-2013, 06:08 AM   #12
Tom Morookian
Tom Morookian's Avatar
I gave up on any of the aftermarket ones looooong ago.
Office Depot - small "binder clips". Pop the 2 tangs out of the black part. With 2 needle nose pliers bend them out from the joint just below the top of the clip. Then bend the tangs down a little to fit flush into the rim.
Nice an "springy" and a custom fit.
Tom Morookian is offline   Reply With Quote
Old 03-20-2017, 08:46 PM   #13
bosborn38pu
bosborn38pu's Avatar
Following a frustrating afternoon attempting to assembly my headlights, I went to "The Barn." Thanks to this thread, the job is done. And a special thanks to Tom Morookian's "binder clip" fix. It works perfectly.
bosborn38pu is offline   Reply With Quote
Old 03-21-2017, 05:07 AM   #14
A bones
A bones's Avatar
Originally Posted by jfcrash View Post
First picture is the new repro and the second is my original clip Jim
This deserves a new question. How are photos such as those shot?
Thank you.
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 03-21-2017, 06:51 AM   #15
corvette8n
corvette8n's Avatar
Thank you.
Depends on the camera, most cameras and phones have a close-up or macro setting to focus close, the problem is holding it still, especially the phone.
On my digital SLR I use a +1 or 2 aux lens and a tripod.
Old 03-23-2017, 08:52 AM   #16
J Witt
J Witt's Avatar
Great suggestion, Tom. Thanks.
John
Houston, Tranquility base here. The Eagle has landed.
J Witt is offline   Reply With Quote
Old 03-27-2017, 03:21 AM   #17
Mick35
Could someone please enlighten me on where I might find the retaining clip that protrudes through the top slot of the headlight bucket for the headlight rim to hold on to on a '35-'36? I've seen the same type of clip listed in several aftermarket catalogues, but for '28-'29,'30-'31,'32, and '33-'34 models only. Regards, Mick.
Mick35 is offline   Reply With Quote
Old 03-28-2017, 02:17 AM   #18
tiger.1000
I usually get some .025" piano wire and make my own
tiger.1000 is offline   Reply With Quote
Old 03-29-2017, 05:59 AM   #19
Mick35
Here's a couple of pictures that will hopefully display the type of clip I am chasing.
File Type: pdf Model-A-Ford-Headlight-Rim-Retainer-Cli.pdf (414.7 KB, 35 views)
Old 03-29-2017, 06:30 AM   #20
vulture
vulture's Avatar
I had a number of bags of the aftermarket ones with a few projects I acquired. I was working on a 1932 headlight and opened up a pack of springs and way too strong and chipped the glass when taking it off. I opened another package and bent into a weird configuration .
I have been in the spring and wire form industry for over 20 years . I was hoping to use up stuff just sitting collecting dust and space . So I did that by throwing the packages away and making some tooling for a kick press . I made mine out of .062 302 stainless spring wire that we have cut offs from Motorola antennas and worked great. I am tempted to call macs and give the a quote for springs
So what's the wire form they sell for universal fit ?
Wanted Roadster Pick up thank you COLOR]
vulture is offline   Reply With Quote
