Old 02-28-2016, 01:49 PM   #1
Gabalus
Default Model A pick up and 4 speed
I would like to put an AA trans on my father's model A pick up but what kind of u-joint I need ?
Any solution ?
Gabalus is offline   Reply With Quote
Old 02-28-2016, 02:13 PM   #2
Charlie Stephens
Default Re: Model A pick up and 4 speed
Someone else will provide a detailed answer to your question but I have one. The AA four speed will give you an additional gear that is really to low to be practical except for a couple of unique applications, pulling tree stumps and driving in parades. Why are you considering this?
Charlie Stephens
Old 02-28-2016, 02:36 PM   #3
Gabalus
He wants to climb by a small (narrow) way in order to go to carry wood.
Old 02-28-2016, 04:14 PM   #4
Bob C
Check out this link to Vince's site. http://www.fordgarage.com/pages/aafourspeedachassis.htm
Bob
Old 02-28-2016, 04:45 PM   #5
Gabalus
Thank you Bob C.
Does anyone 've got these parts ?
Old 02-29-2016, 01:24 AM   #6
Mike V. Florida
Mike V. Florida's Avatar
Chaek out this thread, it looks like he wants to go the other way from you,
http://www.fordbarn.com/forum/showthread.php?t=167726
Old 02-29-2016, 02:58 AM   #7
Gabalus
Originally Posted by Pinesdune
In my short time of owning a model A, I've learned one major thing, they changed things on the car constantly through production.
Here's a link to Steve Plucker's site, lots of info, the link will take you to his info on U-joint covers
http://www.plucks329s.org/studies/studies_ujoint.html
How do you mean the transmission shaft is different? If you are referring to the input shaft on the transmission, their are two options, one that fits a multidisc clutch (early 28) and the one for the single disc. Do you have any pics?
Looking for the front bumper emblem that has "Ford, Made In Canada"
Thank you Pinesdune.
No pictures today (car at father's home).
I mean the model AA output transmission shaft is bigger than model A'. So , I can't use model A or model AA U-joint.
No emblem, sorry.
Thank you Mike V. Florida. Very interesting thread.
Old 02-29-2016, 01:36 PM   #8
1955cj5
1955cj5's Avatar
You might think about a different rear end ratio..If you happen to have a 3:78 then a 4:11 might make quite a difference, and it may be easier to change and less difficult to find than an AA bellhousing, throw-out carrier, transmission and bearing retainer, suitable u-joint and clamshell...
You will need to alter your floor boards and re-locate the brake light switch as well..
Where in the world are you? I did not see a location in your statistics..
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 02-29-2016, 02:09 PM   #9
Fullraceflathead
Fullraceflathead's Avatar
My '28 Roadster Pickup has the AA 4 Speed Trans in it. I like it.
You only use 1st when needed. Shift pattern is same as three speed trans during normal driving. 2nd, 3rd, 4th on 4 speed is same as 1st, 2nd, 3rd on 3 speed. Reverse has a lock out that is much safer.
1st is ideal for slow parades and helps prevent unnecessary holding down the clutch pedal wearing out your Babbit thrust bearing.
Much easier to get moving from being stopped on a steep hill. Very little clutch slipping needed.
It does require a lot of changes though to do the conversion correctly.Mine was a factory dealer retrofit in '31 as my trans is dated 2-13-31.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 02-29-2016, 02:58 PM   #10
1955cj5
1955cj5's Avatar
I think if the conversion was well done you would hardly notice the difference, except for that very low first gear.....
I might have kept mine but the case is broken where the pedal shaft attaches..the brake pedal stops are broken off....and it was noisy...counter shafts are hard to find....
First gear on the 4-speed is 6.4:1 where first gear on the 3-speed is 3.12:1.....
Old 02-29-2016, 05:23 PM   #11
Gabalus
Thank you everybody.
He bought a 4.55:1 rear axle but top speed droped dramatically.
I suggested him to use his AA trans...but you tell me it's a bad idea...
Old 02-29-2016, 05:34 PM   #12
1955cj5
1955cj5's Avatar
If you have an AA transmission and bell housing etc. and have the parts then put the AA transmission in....with that 4:55 rear end it will pull stumps if you can get the traction!
It's not a bad idea, it just was not what I wanted.....
Old 02-29-2016, 06:02 PM   #13
Gabalus
I would like to use standard ratio and AA trans. But lots of specific parts are missing to connect AA trans to model A driveshaft and torque tube.
Old 02-29-2016, 06:34 PM   #14
1955cj5
1955cj5's Avatar
Do you have the U-joint for the AA truck?
You must also have a U-joint for the A truck.
Can the two u-joints be dis-assembled and a new combination of the AA yoke on the transmission side and the A yoke on the driveshaft side be assembled?
I have no idea if this will work.....
Old 02-29-2016, 06:41 PM   #15
CarlG
CarlG's Avatar
These are the parts required that will make it possible to install the AA 4-speed transmission into an A "passenger" vehicle:
A-7085-E Rear Bearing Retainer
A-7090-C U-Joint Assembly
AA-7095 U-Joint knuckle retainer.
Also, make sure you check out the link that Bob gave you in Post #4. Vince has all the information there as well.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 02-29-2016, 06:47 PM   #16
1955cj5
1955cj5's Avatar
I will look at my U-joint and see if there are separate part numbers on the yokes or if there is just one part number for the assembly...
I know my bearing retainer is wrong..
Old 02-29-2016, 07:28 PM   #17
1955cj5
1955cj5's Avatar
So here is more information. The part number A-7090-C is not cast into my u-joint.
The number J10517 is cast in the large "AA" end
The number 121-A2 is cast in the small "A" end
The center cross has F-2-5-52 cast in it.
You can see the dimensions of the cross...
I hope this is of some use.....!!
Old 03-01-2016, 04:09 AM   #18
Gabalus
Thank you CarlG and 1955cj5 for parts numbers, dimensions and pictures.
Now, I "just" need the 3 parts...
( or,eventually, a retainer bearing and try to assemble my model A and AA U-joints.)
