Old 04-27-2014, 05:54 PM   #1
cw253748
cw253748's Avatar
Default bent front axle
I have a 31 tudor with a bent front axle. Anybody here know a good frame shop around the Rockford Il. or Madison Wi. area to fix it? thanks
cw253748 is offline   Reply With Quote
Old 04-27-2014, 06:27 PM   #2
J Franklin
J Franklin's Avatar
Default Re: bent front axle
Ask at a Truck stop.
Old 04-27-2014, 07:00 PM   #3
Ed Saniewski
Ed Saniewski's Avatar
A friend of mine is a machinist and he was able to straighten out a few axles I had. See if a local machine shop can help you out. A 50 ton press can do a lot in the hands of someone who knows what they are doing. We made a set of rod's that go in the holes so we could see when the axle is correct. I don't remember who posted how to make the rods.
Model A Ford Club of New Jersey
http://www.mafcnj.org
Model A Pick Up Owners and Enthusiasts
http://www.fordbarn.com/forum/group.php?groupid=5
Ed Saniewski is offline   Reply With Quote
Old 04-27-2014, 07:22 PM   #4
Ed Saniewski
Found it, this is the link to Kevin in NJ web site on straighting the front axle. "]http://home.comcast.net/~68c/Front_axle_straightening.htm[/URL]
Old 04-27-2014, 09:01 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
You might contact Ken Ehrenhofer in Woodstock. He can't be too far from you. Ken has straightened front axles and has the press to do it.
Old 04-28-2014, 09:44 AM   #6
Mike Peters
Mike Peters's Avatar
Chris: You are welcome to come out and work it back straight with a 20 ton jack, wood blocks, under a very heavy tractor drawbar. I straightened a badly bent Model A frame perfectly a few years ago doing this. Might also work on your front axle. Call me and I will explain. mike
Mike Peters is offline   Reply With Quote
Old 04-28-2014, 12:36 PM   #7
Doug in NJ
Doug in NJ's Avatar
With my front axle disassembled, I was easily able to remove a bend with a 12-ton (HF-grade) press. See this page for some photos and an explanation of how I checked the alignment: http://31ford.dougbraun.com/suspension_work
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 04-28-2014, 02:15 PM   #8
Mike Peters
Chris: Just thought of something else. You will need to press out the spring perches and remove the wishbone before any straightening operation. The wishbone will be in the way. Ed makes a very good point about using straight rods in the kingpin holes. They will indicate if any twisting has occurred. That will affect steering more than anything.
