10-09-2021, 06:39 PM | #1 |
Engine cowl louver reattachment
Several louvers have detached (bottom only) on the engine cowl of our newly-acquired 36 phaeton. To preserve the otherwise-undamaged paint, I’ve been avoiding “thermal” reattachment, whether solder, etc., but am not having much luck with epoxies given the edge nature of the failure.
Two questions: - What would be the correct repair method ? - What is the best wrong method ? Thank you !
No job’s done ‘til it’s all done |
10-09-2021, 09:44 PM | #2 |
Re: Engine cowl louver reattachment
engine cowl louvers?
Hood side louvers, inner fender louvers, cowl vent, or just what location are you referring to? |
10-09-2021, 09:46 PM | #3 |
Hood side louvers, inner fender louvers, cowl vent, or just what location are you referring to here? |
10-10-2021, 04:26 AM | #4 |
Hood side louvers, thank uou
10-10-2021, 04:27 AM | #5 |
*you
10-10-2021, 05:31 AM | #6 |
There is only one way to repair and that is to weld and re-paint. Anything else will most likely not survive the flexing that happens in the panel (not to mention looking like crap) Otherwise, leave it alone and don't tell anyone it's cracked.
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 10-10-2021 at 05:39 AM. |
10-10-2021, 02:59 PM | #7 |
Exactly the issue - was afraid tack weld might be the only solution. Thank you - will add to the list.
10-10-2021, 04:49 PM | #8 |
Yes, tack weld is a partial solution but it could be welded and finished so that no one would ever know it was
10-10-2021, 05:34 PM | #9 |
Tig or you will warp the whole side
10-10-2021, 06:35 PM | #10 |
Will request TIG vs MIG if the former will put less heat in the panel
