08-07-2022, 01:19 PM | #1 |
wheel studs
Putting a set of aluminum wheels on a set of 1940 hubs and the studs are about 1/2| short. any idea where to get longer ones?? Be a big help.
Gramps |
08-07-2022, 03:23 PM | #2 |
Re: wheel studs
Hey Ron, looked several places. The best result was from Speedwaymotors.com Several choices by searching "1940 Ford axle lug studs over length for aluminum wheels
Enjoy yer day. Tom Hate can't fix what it started. |
08-07-2022, 04:26 PM | #3 | |
Re: wheel studs
It ain't that simple, believe me! Just removing the factory studs is no easy process....IF DONE CORRECTLY. To remove, the swage must be cut away on each stud with a 5/8" hole saw. Then, you must press each stud out the back side, taking care to support each stud being pressed with a tubular support to press the stud's head into. If un-supported, you WILL bend the hub flange.....NOT COOL! Your best bet will be to find a DORMAN stud of the length you need, that has a 0.600" diameter shank with something like about a 0.621" knurl diameter. You'll have to ream the five stud holes to the 0.600" diameter before pressing studs into flange, WITH A SIMILAR TUBULAR SUPPORT backing-up each stud when pressed into flange. Coop . Last edited by V8COOPMAN; 08-08-2022 at 11:08 AM. |
08-07-2022, 05:32 PM | #4 |
Re: wheel studs
And, I'm sure Ol' Ron probably knows this, but anytime you replace studs check your lug nuts often as they can loosen up if a stud is not seated all the way down
08-07-2022, 09:23 PM | #5 |
Re: wheel studs
The online Dorman hardware catalog is the best source for finding wheel studs. It lists their line of wheel studs with each stud shown in a photo with complete specs including knurl diameter, shoulder diameter and length and overall length. There are a huge number of 1/2 inch studs available.
John
Those who do not move do not die, but are they not already dead? |
08-07-2022, 10:09 PM | #6 |
Re: wheel studs
08-07-2022, 10:26 PM | #7 |
Re: wheel studs
Thanks Coopman and others for this information. I've never done this beore and have a fellow near by who has. He asked me to get the studs and he'll install them. I realize tha just wacking the old ones out and ponding the new ones in isn't quite right. It depends on the "stupid factor" for men, we wake uo with a rather low 2 to 3 SF. girls are near zero when they wake up. However it gets worse as the day goes by. Starts to get expensive when it gets over 6 or 7.
Gramps |
08-08-2022, 06:20 AM | #8 |
Re: wheel studs
Call me old fashioned, but don't we use lug nuts on alloy wheels? The shank of the nut extends down the oversize hole in the wheel. It is not normally necessary to fit longer studs.
Like the Mag seat lug nuts in the image. |
08-08-2022, 06:35 AM | #9 |
Re: wheel studs
Thanks Mart, but I don't want to modify the wheels to use thedifferent nuts.. Might change them if I were to go racing.
Gramps |
08-08-2022, 06:40 AM | #10 |
Re: wheel studs
Might be smart move to go over what procedure the fellow that has "done it before" used previously plans to follow this time.
Removing swaged studs from early Ford hubs and reinstalling splined studs is entirely different deal as outlined by V8Coop above. I use the following studs; but you would need to check to see if these will work with your aluminum wheels. Dormann 610-234 studs are 1-5/8" long and require the hole be opened up to .60 and the head clipped. |
08-08-2022, 06:49 AM | #11 |
Re: wheel studs
I had my local NAPA machine shop remove the old studs and put in longer ones. The guy that works at my local shop says he rebuilds about 1 flathead a month.
08-08-2022, 06:50 AM | #12 |
Re: wheel studs
Hey Ol' Ron - most mag/aluminum wheels are specifically designed to use a long shank lug nut. Measure the diameter of the wheel holes - as well as know if they have a taper at the top for centering. There are 'standard' designs that many brands use.
I recently purchased a set of Rocket Racing Wheels - their 'Igniter' series (kind of a Halibrand copy) - they work fine on early Ford hubs, but you have to buy the correct style/length of lug nuts to reach down through the thick aluminum flange. |
08-09-2022, 09:15 AM | #13 |
Re: wheel studs
Well, the only wheels that I could fing came from a 91/2010??? Jeep GC 16 x7 5x 5.5. However the addition of the brake rotor complicated the issue. Working with a limited budget.
Gramps |
08-09-2022, 09:18 AM | #14 |
Re: wheel studs
Here is how I did it.
https://www.jalopyjournal.com/forum/...-hubs.1128114/ Scroll down to the end to see the studs and methods I ended up using. Hopefully the non HAMB members can see the pics. |
08-09-2022, 11:06 AM | #15 |
Re: wheel studs
Ron
I got some 1 1/2 inch long studs recently from cw moss for new drums with old hubs I was doing for a guy who is using 35 wires in the later drums. The studs worked out fine and were a bit longer as needed. Larry |
08-09-2022, 11:46 AM | #16 | |
Re: wheel studs
This link BELOW that "alchemy" has posted has some great information for a "BACK-YARDER" undertaking this stud replacement. https://www.jalopyjournal.com/forum/...-hubs.1128114/ For anyone not able to see the pictures, these four pics should tell the story. BIG PICS for RON. Coop . Last edited by V8COOPMAN; 08-09-2022 at 12:24 PM. |
08-09-2022, 03:28 PM | #17 |
Re: wheel studs
Yes, I see how it has to be done, but I'll leave it up to the professionals. I nosiest the hub in the photo had another bolt postern, I was going to buy a set of aluminum Ford hubs with the 3 on 4.5 wheel pattern because there are so many wheels with tthis pattern, however, thes cost almost 700bucks for the pair, I have several grand in the chassis and almost the same in the engine, IF??? I ever get it running, i will need a sponsor to get it to louden for it's 100 mile per lap. be awhile tho.
G |
08-09-2022, 06:58 PM | #18 |
Re: wheel studs
Just about anyone with a Bridgeport mill can put an extra bolt circle in those hubs. I have a friend who taps the hub to 1/2-20 and screws socket head capscrews in from the rear for studs so he can just screw them in and out while still on the car
08-09-2022, 08:19 PM | #19 |
Re: wheel studs
My 40 hubs in the picture were some swap meet purchases (probably about $30 worth, I'm a cheapskate) that had been used for a hot rod in their mid-life. I thought they would enjoy returning to an old Ford pattern in their twilight years. They did. Now they can either get a nice original Ford drum slipped over them, or a pair of the new Boling Brothers repro drums. The studs are long enough for either.
I had my buddy with a mill do the oversized drilling, mostly because he could center every hole. But also because he had the odd size bit. After he was done I ground the one side flat on the stud head, then pressed them in with my Horrible Freight 20 ton press. My part took about an hour for two hubs. One other thing I want to point out, is that I had the face of the hubs trued on a brake drum lathe before I pressed in the studs. I wanted to be sure they would have zero wobble in them after a lifetime of abuse. |
08-09-2022, 08:53 PM | #20 |
Re: wheel studs
Just remember one thing, you can NOT run an alloy wheel directly against a thread. (At least not for very long)
