07-22-2022, 12:21 PM | #1 |
226 flathead Ignition timing
Hello everyone I'd appreciate some advice on how to set the timing for my 226 flathead 6
I have a little knowledge on how to get at TDC and line up the little dot on the pulley with the pointer But I get stuck with adjusting , I have a timing light and a vacuum pump so which would be best to Use? Also my carburetor is a aftermarket single barrel It's a generic brand any help would be grateful 🙏 |
07-23-2022, 12:03 AM | #2 |
Re: 226 flathead Ignition timing
What year or model? The G was early and an H was later. I have an H and adjusting timing is rather normal by rotating the distributor. Does the G have it's distributor on the front of the timing cover facing the radiator?
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
07-23-2022, 12:14 PM | #3 |
Yes it is a h series motor
1949 Do I need to use a timing light to adjust or vacuum |
07-24-2022, 11:10 AM | #4 |
