08-12-2022, 02:59 PM | #1 |
1950 car Seat Mounting Bolts
Anyone know size of bolts that hold front seat to frame rails in a 1950 Ford Car?
08-13-2022, 05:04 PM | #2 |
Re: 1950 car Seat Mounting Bolts
Maybe 3/8 coarse thread?? Been a long time since I had my 50.
08-13-2022, 06:40 PM | #3 |
if i remember correctly they are 5/16 coarse thread because you use a 1/2 inch wrench
08-16-2022, 10:10 AM | #4 |
I'll try each size to get it right, thanks.
08-16-2022, 11:16 AM | #5 |
Body parts catalog shows a 3/8-16 x 2” bolt with lock and flat washers.
08-17-2022, 08:36 AM | #6 |
biscuits and a shim or two do not move. Although they are most likely corroded to the body or the frame.
Henry Ford designed the flathead without the aid of a computer. |
08-17-2022, 08:39 AM | #7 |
Dan has the correct info. Also be careful that the body mount rubber biscuit and possible
shim(s) do not move, as the bolt passes through the mount and into the frame. Likely the rubber is corroded and 'fused' to either the body or the frame.
