03-19-2022, 09:10 AM | #1 |
Water pump install question
What to use on pump to engine interface grease on gaskets or RTV?
Nomad |
03-19-2022, 09:30 AM | #2 |
Re: Water pump install question
I use 'GasgaCinch' on many gaskets - it is a very thin sealer that comes in a can with an applicator in the top. I have used it for 40+ years on things like water pump surfaces, intake manifolds, etc..
RTV works fine as well (for waterpump gaskets), just don't buy the "blue kind" - looks like Hell no matter how much you wipe off! Link: https://www.jegs.com/i/SCE-Gaskets/829/G1614/10002/-1 I use RTV on the oil pan and the ends of the rear/front main rope seals. Depending on the head gasket material, I usually use spray on 'CopperCoat' on them. One some applications I use Hylomar for the head gaskets (solid copper head gaskets). Gasket sealers are one of the subjects where you'll get many opinions - and many different products and processes that ALL work . . . just pick your poison! |
03-20-2022, 10:38 AM | #3 |
On my 8BA water pumps I use a thin coating of PERMATEX Non-Hardening gasket sealer.
Be sure to read this thread about NOT using RTV and silicone https://www.fordbarn.com/forum/showthread.php?t=311227 Last edited by 19Fordy; 03-20-2022 at 12:18 PM. |
03-20-2022, 11:45 AM | #4 |
Me too (Permatex).
03-20-2022, 12:47 PM | #5 |
Grease
03-20-2022, 03:03 PM | #6 |
Anthony....Not to change the subject, but did you ever get your spindles/brakes project completed? I don't remember seeing any resolution on that. DD . |
03-20-2022, 04:41 PM | #7 |
The one time I used grease, it leaked. Always use Permatex or like product which never leaks.
03-20-2022, 07:00 PM | #8 |
another vote for non hardening gasket cement [permatex] defiantly not rtv of any kind
03-20-2022, 07:08 PM | #9 | |
Tighten it tighter. lol
03-20-2022, 07:47 PM | #10 |
Never had a problem with RTV - you have to use a very thin coating
03-21-2022, 03:39 AM | #11 |
I use grease never had a leak (yet!)
Rolls Royce use Hylomar Blue on their engines I think -they don't leak much either
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me. Last edited by Karl; 03-21-2022 at 03:51 AM. |
03-21-2022, 10:10 AM | #12 |
DD, New info on juice brake project. While I did get the spindles reamed & KP’s fit well, I was planning on doing work in a metal pole building a friend is having built because my garage is pretty tight. But with builders being crazy busy it got postponed til April / May which puts us into May /June for a start. As I did quite a bit of engine refresh last season & don’t want to lose another season I think I’ll have some fun with it this season as is with the mechanicals which work as they’re supposed to & do the juice brake project in late fall later this year. I’ll definitely post progress when I start.
Nomad |
03-21-2022, 10:14 AM | #13 |
Thx guys, I was leaning towards grease. It must have been assembled last build with grease, came off very easy & can barely see any residue barely had to clean & never leaked. Just putting hi-flow unit in.
Thx
Nomad |
03-22-2022, 05:26 PM | #14 |
Hylomar was developed by the RAF to stop leaks on Rolls Royce-Merlin engined Spitfires. You could say it helped win the war.
RIP Tyler... My Son, Helper & Best Friend. Feb '78 to Father's Day '10. www.97-express.com ~ [email protected] |
03-22-2022, 09:02 PM | #15 |
Part of the reason that Hylomar is such a good sealer is that it never truly sets up - it remains elastic, and fuel does not touch it . . . so it is good for many things. I have it in cans with applicators as well as spray-on. I use the spray on for blown applications with 0-ringed heads.decks and solid copper gaskets - works really well. But - it is not cheap!
03-22-2022, 09:11 PM | #16 | |
03-23-2022, 12:09 AM | #17 |
thin layer of 'Right-Stuff'.... another one that is 'not cheap'
03-24-2022, 07:56 AM | #18 |
03-24-2022, 09:51 AM | #19 |
What colour Hylomar?
03-24-2022, 07:37 PM | #20 |
The only color I've seen was blue . . . but I've not looking to see if there were others.
