11-23-2023, 09:59 PM | #1 |
leaf spring color
What color are the leaf springs? Black, yes, but flat black paint, gloss? Or Black Oxide?
And if Black Oxide how does one redo them? Caswell has a great black oxide coating, but one would have to make a huge tank to do that many springs one at a time.
Steve in Denver |
11-24-2023, 08:32 AM | #2 |
Re: leaf spring color
Steve, I have the individual leaf's powder finished in what the place calls "box black".
Not flat and a tad less than a satin. Closer to a satin. make sense?
11-24-2023, 12:39 PM | #3 |
If it is not for judging, I iron Parkerize them. Beside preventing rust, it reduces friction between the leaves. The color is satin black.
11-24-2023, 01:18 PM | #4 |
Mike,
With respect, the NOS '32-'36 springs that I've had tended to have a gloss black finish or something between satin and gloss. |
11-24-2023, 04:53 PM | #5 |
I was planning on desassembling them and having the springs blasted. I know there is padding that can go in between each leaf. Is that what Henry did? Seems like that would raise the car quite a bit.
Steve in Denver |
11-24-2023, 05:23 PM | #6 | |
From my experience, mostly '39 - '40, the NOS springs were always satin or a bit less. I'd installed NOS springs in my '36 roadster three years ago and they too were more satin than gloss. Is it possible we interpret the level of sheen differently?
11-24-2023, 05:28 PM | #7 |
Satin or Gloss, what keeps them from wearing the paint off and squeaking?
Steve in Denver |
11-24-2023, 05:46 PM | #8 |
Lubrication between the leaves.
11-24-2023, 05:48 PM | #9 | |
Henry did NOT do this.
11-24-2023, 06:06 PM | #10 |
I know there was a grease zerk, so, no I won't add the spacer things.
Next question, how does one get those keeper things off and back on? Or are there new rivets available/
Steve in Denver |
11-24-2023, 06:28 PM | #11 |
If you mean the rivets on the two clamps on the leaves, Thirdgenauto.com offers a faux rivet that does the job.
Mike, "tended to", i.e. not in every case. |
11-24-2023, 07:16 PM | #12 |
The fake rivets that Driskell (ThirdGen) are wonderful. I highly recommend you follow Dave's suggestion and get them.
11-24-2023, 07:50 PM | #13 |
And they are just the ticket for riveting together '32-'34 shock links as they were originally.
11-24-2023, 08:04 PM | #14 |
Thanks everyone for your input. I will let you know how the project progresses, but it may be a while.
Steve in Denver |
11-24-2023, 08:41 PM | #15 |
Somewhere, I read, heard, or was told, that springs should not be sandblasted. Is that just an old significant other’s tale, or is there some merit to that claim?l
11-25-2023, 08:48 AM | #16 | |
The heat generated by blasting would not be significant to alter the steel. Pitting? Gosh, unless a guy was using small rocks, I can't see how that would be an issue either. I have had my individual leaf's glass beaded in the past. I can understand why a person should not blast a spring assembly.
11-25-2023, 10:22 AM | #17 |
Thanks Kube. Unless they are severally rusted, light blasting should clean them up.
Steve in Denver |
