08-18-2022, 10:49 AM | #1 |
Lower Radiator Hoses
There is a for sale ad on a website that maybe what I need. The problem is the dimensions are given in millameters. The length is given as 210MM and diameter as 45MM. By the picture the would be ok. It's the diameter that I need in inches. These lower hoses are for my 1951 Ford V8 which are 1 3/4 inches. Can anyone assure me that 45MM is the same as 1 3/4 inches?
DD658 |
08-18-2022, 10:52 AM | #2 |
Re: Lower Radiator Hoses
45mm/25.4(mm/")=1.77165.
Here's a tip : go to google and type in "45mm-". It'll give you the answer. It looks close enough since its rubber. |
08-18-2022, 11:08 AM | #3 |
tubman has 45mm correct.
210mm is 8.26 " Just checked a 45mm hose I have on a 36 w/pump(outlet 1 3/4") and its loose Last edited by deuce lover; 08-18-2022 at 11:46 AM. |
08-19-2022, 11:08 AM | #4 |
Thanks for the info. It's appreciated.
DD658 |
08-19-2022, 11:47 PM | #5 |
08-20-2022, 10:44 AM | #6 |
Thank you for the conversion table. Just put it in my favorites for future use. Roger
DD658 |
08-20-2022, 10:49 AM | #7 |
Although this is slightly off-topic, the very phrase “lower radiator hoses” immediately conjures a stream of profanity (in my mind)
No job’s done ‘til it’s all done |
