Old 02-26-2012, 11:39 AM   #1
dennisonk1957
dennisonk1957's Avatar
Default Light Controls '29
Suggestions please...our center light switch is on for lights but when the wheel is turned, the lights go out until the wheel is back to center. Can't drive it at night like this...can anyone (this is funny, because I know you can and willingly will ) help with suggestions. Thank you all in advance. Kris
"The Family Ford"
dennisonk1957 is offline   Reply With Quote
Old 02-26-2012, 11:56 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Light Controls '29
You have binding in the steering column shaft. You may have to remove the horn rod/light switch and clean the tube, and make sure the horn rod is straight. Make sure the thin brass bushing is at the top of the steering tube and lightly lube the horn rod as you reinstall it.
Old 02-26-2012, 04:21 PM   #3
dennisonk1957
Thanks Tom...I will get to that as soon as I can...the list is long including honeydo's. Fences, gates for her horses....this brings me back to the member who posted how much time we spend on our hobbies....thanks again..Kris
Is that your train?
"The Family Ford"
Old 02-26-2012, 07:47 PM   #4
Tom Wesenberg
Is that your train?
I wish that was my train! I couldn't live long enough to afford such an engine. Even a 1/4 scale would be a lot of fun.
Hang on to your horses. The way the gas prices are going we will all need to go back to them and they will become more valuable than Model A's.
