03-13-2016, 07:49 PM | #1 |
Oil pan plug question
Guys,
I twisted the bung out of the pan where it was soldered in: What kind of solder do I need to put it back in? Can I use the same stuff to close pinholes in the dipper tray too? Thanks in advance. R /Roger. |
03-13-2016, 08:01 PM | #2 |
Re: Oil pan plug question
I clean the area THROUGHLY, weld the bung in place the solder to make sure it does not leak. general metal work solder. yeah, solder will fill the pinholes in hte dipper tray.
03-13-2016, 09:02 PM | #3 |
I would use silver solder or braze the bung in place.
03-13-2016, 09:11 PM | #4 |
03-14-2016, 04:59 AM | #5 | |
Some folks are scary about using Silver Solder, but it's EASY & stronger than solder. By the way, will a spark plug washer fit the oil drain plug?? Bill W.
03-14-2016, 09:02 AM | #6 |
03-14-2016, 06:09 PM | #7 |
Thanks guys.
03-14-2016, 06:36 PM | #8 |
I resoldered mine when it came loose a few years back. I make sure now that the washer is in good condition and don't tighten it very much. No problem since and hoping it stays that way.
As for silver soldering, there are 3 golden rules to do that job: 1. The job MUST be clean. 2. The job MUST be clean. 3. I'm sure you get the idea! To get the area hot enough for silver to melt, the lead/tin solder has burned to a mess and I don't think silver will flow properly. I think I'd completely remove the boss into which the plug screws from the sump, clean it (maybe by blasting) and go from there, maybe welding rather than silver What a PITA it was when mine let go, I was 2,500 miles fro home and the car HAD to be serviced. I was in an empty warehouse alone and had to remove the sump to drain the oil, refit and refill. Why is it that these things always go wrong at the worst possible moment?
