Old 02-22-2024, 11:24 AM   #1
Banditorama
Default Speedometer "sticking" at random
The oval Speedometer was in rough shape originally when I first got the car. I took it apart, cleaned it, lubricated it, and re-stickered everything. After a few hiccups I've got the odometer, trip meter, and speedo "working".
But, the speedometer wheel itself is wobbly as it scrolls up and down in speed. Also, it's intermittently getting hung up at 10 to 15mph (one time 35) as the car decelerates to a stop. If you give it a firm couple taps it come back down to 0 or if you roll over a bump as you're coming to a stop it'll keep moving. It doesn't hang up all the time but will hang up several times during a drive
The odometer and trip meter are working correctly. The numbers move smoothly and continue to register miles even if the speedo is hung up.
Banditorama is offline   Reply With Quote
Old 02-22-2024, 06:29 PM   #2
Ted Duke
Default Re: Speedometer "sticking" at random
You may need grease at the turtle?
Ted Duke is offline   Reply With Quote
Old 02-23-2024, 10:08 AM   #3
Banditorama
You're referring to the speedometer drive gear housing bolted to the transmission that the speedo cable screws into, right?
If so, I took that off, inspected, and greased it up.
Old 02-23-2024, 10:38 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
Grease is the wrong lubricant for the speedometer cable. Grease congeals in cold weather, so the cable will turn erratically. Use graphite powder to lube the cable. Also, if you over grease the U-joint, that grease will get into the speedometer cable. As for the speedometer, a very light oil applies sparingly is good. Do not use grease in the speedometer.
Bob Bidonde
Old 02-23-2024, 10:58 AM   #5
arnhemmer
I used graphite on the cable and clock oil inside the speedometer.
arnhemmer is offline   Reply With Quote
Old 02-23-2024, 12:36 PM   #6
Banditorama
Inside the "turtle" where the gears live I used grease
For the speedo cable I used a white lithium grease
Inside the speedo itself I used sewing machine oil
Old 02-25-2024, 06:40 PM   #7
papanick
it sounds like the speed wheel is out of line that would make it hang up at time.
papanick is offline   Reply With Quote
Old 02-26-2024, 07:28 AM   #8
jack wingard
or the pivot ends could be worn or slightly bent
jack wingard is offline   Reply With Quote
Old 02-26-2024, 11:37 AM   #9
Banditorama
Next time I have it apart I'll have to check the alignment of the speed wheel. Is there a procedure to check that?
Jack, when you say pivot ends, what part are you referring to?
Thanks guys
Old 02-27-2024, 06:48 AM   #10
jack wingard
Thanks guys
It's the end of the shaft/arbor that steps down in diameter that then inserts into a bushing. Simular to a motor shaft bearing setup. On a motor the shaft fits tight to the bearing.
A pivot spins freely inside the bushing.
Old 02-27-2024, 09:15 AM   #11
Dino's A
Dino's A's Avatar
There is a specific type of lubricant for speedometers still made.
Just can't find where I it put it!
White grease will work, I have used it at times. Maybe it's not the best,
but in So Cal, I get away with the warmer temps allowing me to use it.
1928 Roadster Pickup
1930 Tudor
1943 Ford WWII Jeep
1968 Taco Minibike
Member, Santa Anita Model A's
Arcadia Ca.
Dino's A is offline   Reply With Quote
Old 02-27-2024, 09:56 AM   #12
gary678*
The vendors sell a graphite speedometer cable lubricant. I put in a new cable 4 years/8000 miles ago, used the graphite lubricant, and it has performed perfectly; spot-on MPH and odometer readings. I was told by Model A friends to not use grease!
gary678* is offline   Reply With Quote
Old 02-27-2024, 03:41 PM   #13
Jim M
Jim M's Avatar
I did the exact same thing as Gary and it has worked fine for over 3 years. Not sure where I got the graphite lube but my guess is Bert's.
Jim M is offline   Reply With Quote
Old 03-16-2024, 10:39 AM   #14
Banditorama
Update: Problem Solved!
I followed most of the instructions for rebuilding it from here:http://www.modelahouse.com/tech/spee...r/fischer.html
Per that site, I set the speed cup up/down play to 0.015" play. The speed cup was ever-so-slightly dragging on the odometer wheels that sit underneath it. I got some little washers and put them under just the front two screws that hold the entire speed cup assembly in place.
That threw the speedometer reading but I was able to fix that by adjusting the magnet plate. I verified I had it right with GPS and it reads 100% on the money accurate speed. No more hang-ups and the odometer, speedo, and trip meter are all fully functional.
Thank you everyone for all your help between this thread and all the other ones I've had trying to get this speedo working properly!
Old 03-16-2024, 11:48 AM   #15
Ray in La Mesa
Glad to hear you solved the problem. Also glad to see all the speedo info I posted on the "Model A House" technical site years ago helped your project. Ray Beardslee
Ray in La Mesa is offline   Reply With Quote
