04-21-2016, 11:22 AM | #1 |
Installing tires on Rims
Literature tells me that if my rims are extremely pitted or rough, it is recommended to use flaps instead of rim liners.
My rims are extremely rough, so I added rim flaps. Question, do I install the rim flaps before or after installing the tires? |
04-21-2016, 12:34 PM | #2 |
Re: Installing tires on Rims
Those flaps are for AA truck wheels, and not the Model A rims. Just use the regular band.
04-21-2016, 12:56 PM | #3 |
I contacted the part supplier who assured me that the part number that I have is the correct flap for the model A wheel. There is a different flap part number for trucks, and a different flap part number for T's.
Thanks, |
04-21-2016, 01:02 PM | #4 |
I've wrapped rough rims with several layers of duct tape before
04-21-2016, 01:09 PM | #5 |
Do you feel any spots on your rims that could poke a hole in the tube? If you do then grind it smooth. I suppose you have a fair amount of money already invested in painting the wheels, and I think they will work OK with the common rim band, but I would have found some rims with less rust. I'd bet Bert's has some because the western states are so much better (drier) than those east of the Mississippi.
04-21-2016, 01:21 PM | #6 |
04-21-2016, 01:25 PM | #7 |
Use the flaps it provides added protection. Your rims do look rough. I have coated some riveted rims (not A) with silicone rubber with a brush before using tubeless tires to avoid leaks and it has all worked well too.
04-21-2016, 07:07 PM | #8 |
If your wheels run true, and are in good shape otherwise, there would be no real sense in replacing them. Good wheels are hard to find and nobody will see the inside of the rim.
04-21-2016, 07:22 PM | #9 |
My question still stands, do I install the tire after installing the flap? Or do I install the tire and then the flap?
Thanks, |
04-21-2016, 07:33 PM | #10 |
I take my new tires and restored rims to Big O tires. They install the tires without scratching the rims for $8 each.
04-21-2016, 07:57 PM | #11 |
Put the tube in the tire, then the flap, then alittle air in the tube, then use a cheap plastic garbage bag to install the tire onto your rim. Do a search about this method for installing tires. You cover the rim with the bag, stick your tube valve stem into the hole and use a clamp to keep it from pulling out as your tire tube flap slide onto your rim. Work it around pushing both beads over the rim, ya gotta get the beads to set in the drop center of the rim when you start. I mount my rims on my spare tire carrier to use as a work platform. Works good. Good luck
04-21-2016, 07:57 PM | #12 | |
I would take a tire, put the inner tube in it, and inflate it just enough to make it take shape, then tuck the flap in all the way around-then install the tire on the rim. |
04-21-2016, 08:09 PM | #13 |
I think you're pushing the envelope on "pitted and rough". I'd want some better wheels. However, since you already have all that stuff, might as well give it a shot. If it were me, I'd use some 3M weatherstrip glue (Monkey Snot) and glue the flap to the wheel first, then just mount the tire and tube like normal. Good Luck
04-21-2016, 08:57 PM | #14 |
I used those flaps, I installed one bead of the tire on the rim, slipped the flap and the tube in the tire, got it in place, then pryed on the other tire bead over the rim and inflated. It's just how I did it, I won't say it was right/wrong/or ?, but thats how I did it and it worked fine. Did it on freshly powder coated rims, used an old heavy towel to protect the rim inn case the tire iron slipped.
04-21-2016, 09:41 PM | #15 | |
For lube, I use a 50/50 mix of dish soap and water. PS. I apologize for the UK spelling, but that is the way my computer is set up. Last edited by ian Simpson; 04-21-2016 at 09:53 PM. Reason: Brain phart. |
04-21-2016, 09:52 PM | #16 |
This is how Ford installed tires and tubes
http://youtu.be/PflFp8Cdrzc |
04-21-2016, 10:23 PM | #17 |
After the 1000th one you kinda get the hang of it!
04-22-2016, 12:12 AM | #18 | |
04-22-2016, 12:49 AM | #19 |
If you look closely in the beginning the tube is inside the tire partially inflated as you can see the valve stem sticking up.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
04-22-2016, 04:58 AM | #20 | |
