Old 07-19-2015, 05:07 PM   #1
Big hammer
Default Head removal
Not having the proper tools, I used a rope in the hole trick! #1 piston down and #4 I push 12 feet of 1/4 ploy rope down plug hole and push over the piston with a screw driver, then hand cranked the motor. Up came the head 1/8 inch then with a flat pry bar moved head up 1 1/2 inch off it came by hand! Someone had a post and the rope trick was one way to try :-) it works !!!
Old 07-19-2015, 06:01 PM   #2
CarlG
CarlG's Avatar
Default Re: Head removal
The proper tool:
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 07-19-2015, 06:57 PM   #3
Big hammer
No bent rods not like hydraulic lock and yes a real tool would have worked.
Thought someone could use this along the road or when a real tool is not available
Old 07-19-2015, 06:58 PM   #4
bunnyc
bunnyc's Avatar
https://www.youtube.com/watch?v=9QCR-ypFuew
bunnyc is offline   Reply With Quote
Old 07-19-2015, 08:09 PM   #5
James Rogers
James Rogers's Avatar
It is just like a hydraulic lock and you can easily bent the 7" long spindly rods this way. Ask me how I know.
Old 07-19-2015, 08:30 PM   #6
700rpm
700rpm's Avatar
Originally Posted by CarlG View Post
The proper tool:
I've used methods like those in the video, but with mixed results. Carl G has the right answer. That tool makes it so easy it is worth the price if you ever plan to remove a head, especially more than once. I'm fortunate to belong to a club that has one in the club tool chest. It's really the best way to go.
Ray Horton, Portland, OR
