09-03-2011, 11:04 AM | #1 |
clutch question
I rebuilt my engine and transmission over the winter. I used kevlar bands and the turbo 400 clutch set up. installed using the ford book specks. The problem is that when I go to high gear the pedal comes way back tward the driver more so than with the ford clutch set up. What am I missing? I have used watts clutch discs before and not seen this problem.
09-03-2011, 11:19 AM | #2 |
Re: clutch question
When you put together the clutch disk stack did you check the height? It should be 1 1/8 inches. The spring measurement is 100 to 115 lbs at 2 inches compression. Your fingers may be set too high. I have a used set of turbo 400 disk in mine and set the fingers to 13/16 inches measured from the face of the driving plate to the collar.
Here is some more reading; http://www.mtfca.com/discus/messages...tml?1204673019 |
09-03-2011, 11:47 AM | #3 |
Re: clutch question
Thanks Red I'm going to adjust the bands this afternoon and will also adjust the arms and link . The link right now has a bit to much play in it. Frank
09-03-2011, 11:47 AM | #4 |
Re: clutch question
09-03-2011, 11:49 AM | #5 |
Re: clutch question
I put in the spacers and the disk pack as recomended by the supplier. Did not measure it , but was very carefull to follow the instructions.
09-06-2011, 02:44 PM | #6 |
Re: clutch question
