03-24-2018, 10:47 AM | #1 |
Degreasing a tranny
What to you Barners use to degrease a tranny thick with hard grease? Usually I use scrapers and screw drivers and a lot of time. Spray Oven cleaner and put the thing in a trash bag for a week? T don't have steam or high pressure water
03-24-2018, 11:26 AM | #2 |
Re: Degreasing a tranny
You do the same as I do. Everything.
03-24-2018, 11:50 AM | #3 |
My trans was filled, ... YES, filled with grease. It took a pressure washer connected to my hot water heater and Purple Power to clean it after I first hand scooped the majority out.
It took well over an hour and let's just say, ... don't walk in your de-greasing area and then onto your carpet anytime soon. It's the reason I now own a carpet cleaner. Regards Bill |
03-24-2018, 05:43 PM | #4 |
Scrapers, screwdrivers, etc. first to get the chunks off then move to a large shallow pan and spray on carb cleaner a couple of times and scrub with a brush.
03-25-2018, 12:39 PM | #5 |
Help full hint on the pressure washing to keep the mess to a minimum. Take a pallet ant take a old sheet and tack on top of it. Take any old plywood and make a box with a lid to go over the top . Drill some large hole saw type holes around at different locations on top and sides. Spray away The sheet will catch a lot if not most of the sprayed off grease. From what you are cleaning up. It might take a little longer but it will keep a lot of the mess down and off of you .
old car guy |
03-25-2018, 02:09 PM | #6 |
03-25-2018, 08:20 PM | #7 |
Thanks. When I degreased a early model A, I rented a pressure washer, parked the A over some old sheets and blasted away. The sheets caught most of the gunk.
Thread Tools | |
Display Modes | |
