09-27-2016, 10:08 PM | #1 |
Stranded Already!
Well, I've had my Merc for three days and it just left me stranded for the first time. I was going for a short drive after work and was only a mile from home when it started losing power. Pulled into a parking area as it died completely. I could tell it wasn't getting fuel.
I tried to restart it and it would catch, but wouldn't stay running. Opened the hood and immediately saw one problem. The sediment bowl at the fuel pump, which hitherto had nice clean fuel in it, now had basically black fuel in it. See photo. I took the bowl off, carefully poured the fuel out, and there was a bunch of black sediment in it. I cleaned that out, put it back together again and tried to start it with the same result. Bowl once again filled with black fuel and sediment. My wife came and got me and I then came back with tools, fresh fuel, and carb cleaner. I took the line from the pump to the carb off and sprayed out the fuel inlet. I cleaned the sediment bowl out again and filled it with clean fuel. Put everything back together, cranked a few times and it started right up. Made it home just fine. Checked and still had nice clean fuel in the bowl. I suspect a chunk of something came loose either in the tank or in the fuel line and disintegrated. I'll replace all rubber lines. Obviously the one leading into the fuel pump is a likely suspect. I was going to rebuild the carb anyway, but will probably push that up. The prior owner only drove it a few hundred miles in the four years he owned it.
Regards, Scott '47 Mercury Convertible '25 Dodge Bros. Touring Car '63 MG Midget Last edited by jagnweiner; 09-27-2016 at 10:15 PM. |
09-27-2016, 10:18 PM | #2 |
Re: Stranded Already!
What you have come across is all to common flathead ailment and by looking at the old stock flex line on the pump that's likely sucking air .I would remove the tank and clean it or carry a long flex line and a can of gas that can be used in the passengers seat side also a filter next to the carb till you get it sorted , Ted
09-27-2016, 10:19 PM | #3 |
Just a thought, you may want to look at the gas tank also. Years back I "drove" a car that would idle very nice but when you would drive the car you would only get about a mile down the road. It ended up being the gas tank that was corroded inside. Once the car was moving it started all that junk inside and that was it. I am finishing up my '46 Ford convert.
09-27-2016, 10:19 PM | #4 |
nevermind
Last edited by SofaKing; 09-27-2016 at 10:21 PM. Reason: simultaneous posts render this redundant |
09-27-2016, 10:29 PM | #5 |
Because of the age of these ol' cars, many of them do need constant
attention till you get all the bugs out. The good thing is that you got it running again with just some simple tools, and a little ingenuity, good for you. If that was your NEW car that stalled out, you might as well call a tow truck and haul it to your favorite garage. Then draw a good sum of money out of the bank, cause the analyzers and special tools they need to use, to fix 'em cost big bucks, and the parts are even higher than Old Ford parts are. Glad you got it going and hope the enjoyment you get offsets a few glitches. .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
09-27-2016, 11:22 PM | #6 |
lucky we don't have that problem here ...yet !
09-27-2016, 11:29 PM | #7 |
are you using ethanol gas?
09-28-2016, 12:54 AM | #8 |
My 48 did the same thing right after I bought it last year. Every few miles the sediment bowl would fill with junk. Also the fuel tank was supposed to have been cleaned. I put in a new tank from Drake and new fuel hose to the pump, no problems since.
09-28-2016, 05:01 AM | #9 |
Nope. I filled it up with non-ethanol gas, although I don't know what the PO had used.
Regards, Scott '47 Mercury Convertible '25 Dodge Bros. Touring Car '63 MG Midget |
09-28-2016, 06:59 AM | #10 |
The clue might be the black color in the sediment bowl. It probably is the rubber fuel lines. First thing I would do is change them all. I kept smelling gas when I was parked at a car show and I finally looked under my car and it was a short section of hose between the tank and the steel line. It virtually crumbled in my hand and turned to a black "mush".
09-28-2016, 07:24 AM | #11 | |
Just glad I was able to get it going again.
09-28-2016, 10:23 AM | #12 |
Replace the flex hose from the fuel line to the carburetor with one from Bob Shewman. I jut put one on our '47 tudor. He advertises in the V8 Times.
09-28-2016, 10:28 AM | #13 | |
On a related note, I saw that Mac's sells a filter to use in conjunction with the sediment bowl. Is there any merit to installing that? Does it create any fuel flow problems?
09-28-2016, 10:34 AM | #14 | |
09-28-2016, 10:42 AM | #15 |
I would not be messing with any of the fuel lines with the anti-backflow valves until you solve the contamination issues! There are two totally different issues in play. One is physical contamination plugging up the fuel system and the anti-backflow valve will only make that issue worse. The valve is to keep fuel from flowing back into the tank when the car sets for a time. That is not your current issue.
09-28-2016, 10:46 AM | #16 |
I presume not. Does anyone have Mr. Shewman's contact info?
09-28-2016, 10:47 AM | #17 |
09-28-2016, 10:53 AM | #18 |
Hmm, ok . . .
Edit: Ah, missed your first post before I made mine. Now I get it.
09-28-2016, 11:00 AM | #19 |
Shewman makes an anti-flowback version for those who think they need it. His standard version IS a good idea. Who knows if MAC's flex line is fuel resistant as Shewman's is?
Alan |
09-28-2016, 11:14 AM | #20 | |
jagawwiner, if you search some threads on these anti-drain back valves the biggest issue they have is they get clogged up easily. Once you get your fuel system spotless clean then if could be a consideration. But with the present contamination issues it would totally make the system unusable. It is going to depend on where the contamination is coming from of course, but not something you want to be dealing with at the moment. They are only needed if you have a drain back issue in the first place. If I was going to consider using one I would place a filter in the line ahead of the valve, but again, this is not the current problem as you explained it. Last edited by JSeery; 09-28-2016 at 11:20 AM. |
