08-31-2010, 01:42 PM | #1 |
Change to 37 heads in my 36: Pros and Cons
Would there be any advantage in putting 37 heads and water pumps on the 37 block that I have in my 36? It's out of the car in pieces and now would be the time to make any changes. I currently have 36 heads and block off plates on the 37 block. Thanks, Ed
08-31-2010, 02:19 PM | #2 |
Re: Change to 37 heads in my 36: Pros and Cons
The cr might be alittle higher, especially if you mill the heads for .050" piston clearance. Also might cool better. Make sure you clean the block very good. Might consider Bake cleaning.
08-31-2010, 02:29 PM | #3 |
I like to see the '36 bolt on parts in a '36 car (even if the block is later). If you are not having any problems I would leave it as is. If it ain't broke, don't fix it.
Charlie Stephens |
08-31-2010, 06:58 PM | #4 |
I think the lower pumps work better for cooling,something to do with the water flo.i have a 37 block with the lower pumps in a 35, no problems dp
DON P |
08-31-2010, 08:39 PM | #5 |
Thanks guys. Sounds like it would be an improvement. Anyone have a good pair of '37 21 stud heads? Ed
08-31-2010, 11:59 PM | #6 |
09-01-2010, 12:26 AM | #7 |
I have a Rat Rod T bought for parts. It has a 37-38 with block off plates. I have ordered lower pumps and 21 stud heads without the pumps. What year did they go to domed pistons and inserts bearings???.The Rat Rod was lowered and they placed the radiator lower than the pumps. the pumps cant take suction and I got the car for a good price.lots of good stuff for my 29 A High Boy with a Flathead The 37-38 will go in a C cab T if the heads fit.
Thanks I love this Barn. |
09-04-2010, 05:23 AM | #8 |
I need to find early heads for dome top pistons for my fresh LB, have got one cast iron need another to finish and of course I want a pair of aluminum for looks. I have one I use now with flat tops so can't swap em. Have a few dome tops with bad corrosion, doubt that they can be filled.
If someone is swapping around and ends up with a pair of dome top aluminum pump-in-heads, I can use them. |
09-04-2010, 06:37 AM | #9 | |
09-04-2010, 07:59 AM | #10 |
The first LB (insert bearing) engines appeared in October 1935.
... and, Ed, when I look into a '36 engine compartment, I like to see the pumps in the heads. BUT, that's just me.
"Remember that when it comes to intelligence, half of all of us are below average." |
