10-30-2013, 10:26 PM | #1 |
Engines A or B
What is the difference between the two engines and is there a way to tell them apart, reason is my dad has a bunch of engines laying around.
10-30-2013, 10:39 PM | #2 |
Re: Engines A or B
The "B" engine has a place for a fuel pump
The "A" engine has a oil return tube from the valve cover to the block |
10-30-2013, 10:59 PM | #3 |
Re: Engines A or B
B's have a 3 bolt water pump.
A's have a 4 bolt water pump. |
10-31-2013, 01:03 AM | #4 |
Re: Engines A or B
The B oil fill pipe is fatter
10-31-2013, 01:23 AM | #5 |
Re: Engines A or B
Hi Jimmy,
Also, if parts are laying around, or if the oil pans are not installed one can observe that the B crankshaft journals & diameters of Babbitt connecting rod bearings are larger in diameter than that of the A. |
10-31-2013, 01:44 AM | #6 |
ALSO NOTE : Anything other than the basic short block must be viewed with skepticism in determining if a block is an 'A' or a 'B'. As heads are often changed around, the Head/Water-Pump is not a good indicator of the type of engine. Because of the higher compression and the much easier to install / replace, 'goose-neck' / water-pump ( a combined one-piece unit ), of the 'B' (marked 'C') head, they are often installed on an 'A' engine, in place of the original 'A' head. Also, as the timing-gear cover (used to mount the front of the engine to the frame) also can be changed from a 'B' engine (as mounted to the significantly different '32 frame) to the 'A' cover - this indicator also is flawed. |
10-31-2013, 08:23 AM | #7 |
Re: Engines A or B
HOLE in the right side of the block for fuel pump. Definitive.
Paul in CT |
10-31-2013, 10:40 AM | #8 |
Re: Engines A or B
The advantages of the B engine is larger bearings on the crankshaft and mild oil pressure to the mains. The slightly higher compression head adds nearly seven horsepower more than the 4.22 compression model A head. The camshaft has more lift and duration and gives a 600 RPM increase over the model A engine. The B engine is rated at 50 horsepower. On the negative side, the model B blocks are thinner and most will have cracks in the valve seat area.
10-31-2013, 12:01 PM | #9 |
Re: Engines A or B
10-31-2013, 01:04 PM | #10 |
Re: Engines A or B
Later model B engines came with counterbalanced crankshaft...
A more bigger intake with a model B zenith carburetor... |
10-31-2013, 01:22 PM | #11 |
Re: Engines A or B
Wow!!!!!!!!!!!!! Lots of info on that question, thank you very much.
11-01-2013, 02:57 AM | #12 |
Re: Engines A or B
If you post a few pics of what you have, a lot of knowledgeable people on this forum can inform you what is what.
11-01-2013, 06:05 PM | #13 |
Re: Engines A or B
One more question if you do not mind, what is a fair price on an engine if it turns over or stuck, I am going over to dads on Saturday and have a look see.
11-01-2013, 08:55 PM | #14 |
Re: Engines A or B
The least price for a complete stuck B engine with a marvel carb, that I have found nearby was $500.00 . I've seen B long blocks that were said to be free offered as low as $800.00 as a core.
11-01-2013, 09:11 PM | #15 |
Re: Engines A or B
It likely sounded as though I need to make a lot of money "NOT", I am going to see what I can dig up there are even a couple Flatty's, one is hooked to a military welding machine and the other is in a truck. I had better try and get them before the stepmother sells it all off, I offered her 3 grand for the 30 coupe a month ago and then sells it to some picker for the same amount. I am not liked
