10-10-2013, 05:50 PM | #1 |
What is and where does it go??
I know or at least am fairly sure this is a distributor part can you help me?
Last edited by Wisconsinjimmy; 10-10-2013 at 06:40 PM. Reason: Did not subscribe |
10-10-2013, 06:41 PM | #2 |
Re: What is and where does it go??
It is not inside the distributor but in the oil pump drive. It is the bushing sleeve.
10-10-2013, 08:40 PM | #3 |
Brent, I am at a total loss on this, this bushing was in with the parts I took off with the distributor, does it fit in with the oil pump drive gear?
Thanks |
10-10-2013, 10:39 PM | #4 |
Thank you will get it changed in the morning.
10-11-2013, 09:10 AM | #5 |
it is together
10-11-2013, 12:00 PM | #6 |
Thank you, ...great illustration!! |
10-11-2013, 12:10 PM | #7 |
A picture is worth a thousand words! Best illustration I've seen in a long time!
She just don't have the appetite For gas somehow, And Dad, I got four carburetors Hooked up on it now. I tried to hook another To see if I'd do a little good, But ain't no place to put it 'Less I perforate the hood. Wanted, lower side sections of 32 radiator cowl. |
10-11-2013, 02:47 PM | #8 |
WOW that is an OH $%*# where do I start.
Have the engine together and timing dern close and it popped ran for 3-4 seconds I am happy but when by yourself and trying to inject either and operate all the levers and rods from under the hood jeez!!!! Last edited by Wisconsinjimmy; 10-11-2013 at 02:50 PM. Reason: Add another comment |
10-11-2013, 03:01 PM | #9 |
Go easy on the ether, its dangerous and cleans the oil off the rings/guides
10-11-2013, 04:31 PM | #10 |
Well it starts and idles on her own with no either or other help just have to give it a healthy choke and wide open throttle (wot). The brakes do not work, I am going to grease everything and see if that helps but it runs that is a big plus. Now I have to get all over the auction company to get me a title as it does have one. Thanks for the help
Jim |
