10-07-2013, 09:36 AM | #1 |
Babbitting service
Who in the Minneapolis / St Paul MN area does BABBITTING if you can also throw out a phone number or PM me or email (remove spaces) j ganley @ lake land dot ws
10-07-2013, 10:09 AM | #2 |
Re: Babbitting service
Not in the Mn area but I've been talking with Rod Gaffery in SD about doing some for a White engine, he has been recently begun using a spray method and has had good success, I have his number at my shop if you would like it.
10-07-2013, 10:10 AM | #3 |
I am not sure if anyone does babbitting in the Twin Cities are any more. RiteWay used to do it, but they went out of business many years ago. A fellow near Rochester (Elmer LaBrash I think his name was, also used to do babbiting, but he retire several years ago. There is a fellow in Clare, Iowa that still does babbiting. His name is Kohnke and his phone number is: 515-546-4551. It seems like most people are going to inserted bearings. There is a fellow in our model A club in the Twin Cities that does inserted engines. I believe he has done over 100 of them. His name is Dave Gerold and lives in Jordon, MN, just south of the Twin Cities. His phone number is: 952 290 3630
Rusty Nelson |
10-07-2013, 10:19 AM | #4 |
Thank you for the reply, what closes the door on repair is the cost of shipping and engine I will give Dave Gerold a call.
10-07-2013, 10:34 AM | #5 |
If you decide to have Dave do the work, you could arrange to go to one of our clinic meetings and give the block to Dave. Clinics are the 3rd Thursday of the month, with a couple exceptions.
10-07-2013, 11:33 AM | #6 |
10-07-2013, 01:27 PM | #7 |
Are you sure you need babbitting? Have you inspected and measured it yet?
10-07-2013, 01:48 PM | #8 |
I am waiting for my son to get home, how much side movement is permissible on the con rods?
10-07-2013, 02:55 PM | #9 |
.006-.012.
10-07-2013, 03:06 PM | #10 |
Its the main bearing clearance and condition I would worry about first as that is the foundation of a healthy, quiet happy engine. Rod
10-07-2013, 03:26 PM | #11 |
let us know how you make out
'31 180A Last edited by tbirdtbird; 02-03-2017 at 10:47 AM. |
10-07-2013, 05:11 PM | #12 |
Oh, and by the way, maintain the integrity of the shim packs!
10-07-2013, 05:17 PM | #13 |
Sure hope these have a little bit of life in them
10-07-2013, 05:30 PM | #14 |
Looks like they have been adjusted some. How many shims were under each cap on each side?
10-07-2013, 05:48 PM | #15 |
No shims what you see is what came out
10-07-2013, 05:56 PM | #16 | |
10-07-2013, 06:02 PM | #17 |
Shims where would they be between the rod and the cap?
10-07-2013, 06:05 PM | #18 |
Mr. W. J., What is the Black thing on your two pictures at the bottom of your pictures that makes it look like the side of the cap is missing?
10-07-2013, 06:55 PM | #19 | |
Looks like a shadow from the lip of the drawer or toolbox that the rod cap is propped up in. Quite the optical illusion! |
10-07-2013, 06:57 PM | #20 |
10-07-2013, 07:59 PM | #21 |
I see in one of the catalogs rods are available with new Babbitt what needs to be done to get them ready to put on a crankshaft?
10-07-2013, 08:03 PM | #22 |
My post got lost in cyber land, the pic of the caps has a shadow cast over them if you look close you can see the bearing edge.
10-07-2013, 08:15 PM | #23 |
The crankshaft rod journals need to be ground first and then the proper babbitt rods ordered to fit. If you are going to go with inserts for the mains, both the main journals and the rod journals are ground at the same time.
10-07-2013, 08:30 PM | #24 |
The oil grooves are too deep, but that is not fatal. See Kohnke's pics for how they should be done.
I wonder about the little missing chips in the lower pic if that is not the start of a crack/separation, but maybe not. The shims are between the rod and cap in Kohnke's pics. They are shown in the lower left corner of his last pic. New rods, whether from a catalog, or anywhere else, have to fit the crankshaft. You need to measure the journals, and get rods that fit. Clearance is .015". Since you have already talked to a babbitt guy, I would show him your rods and talk to him some more. How do the mains look? |
10-07-2013, 08:44 PM | #25 |
What is the spray method of babbitting? What are it's asvantages? Can it be used to build up worn babbitt and save stripping the old babbitt out?
10-07-2013, 08:52 PM | #26 |
10-08-2013, 02:12 AM | #27 | |
10-08-2013, 09:24 AM | #28 |
10-08-2013, 09:40 AM | #29 |
After some serious thought and discussion with my bride we are going to sell the car, this model a thing is just way over my check book. Again I thank all of you for your help.
Jim |
10-08-2013, 10:27 AM | #30 |
"Clearance is .0015"
Colin--Thank You. I was wonderin' what that noise was. |
10-08-2013, 10:52 AM | #31 |
When the OP said babbiting my little mind whet directly to inserts, as I've been in discussion about making some new bearings for White engines, and Rod had said he was now spraying babbit on the shells, I know nothing other than he says its been working real well.
10-08-2013, 12:34 PM | #32 |
Well, what a coincidence Giles, Happy Motoring. Herm.
10-08-2013, 12:45 PM | #33 |
10-08-2013, 01:24 PM | #34 |
sure is beautiful workmanship, Herm...
'31 180A |
10-08-2013, 01:55 PM | #35 |
10-08-2013, 03:10 PM | #36 |
Are you suppose to take the notch in the babbit all the way to the edge of the babbit ?
10-08-2013, 03:42 PM | #37 |
Is spraying babbitt a form of "metallizing"?
10-08-2013, 04:58 PM | #38 |
"Are you suppose to take the notch in the babbit all the way to the edge of the babbit ?"
I don't think so, else the oil will not stay in the bearing space, it will just leak out; but I wish Herm would address this.
'31 180A |
10-08-2013, 05:11 PM | #39 | |
The oil well which is the oil gully, is on the part line, and the diagonal groove is the oil spreader groove. That groove is fed from the oil wells and should be on the far ends of each oil well, and no the oil wells do not go clear to the ends of the bearings and yes the oil would run out. They should stop about a 1/4, to 3/8's from both ends. If you don't have the oil groove out to the ends of the oil wells, the two ends of the crank bearing does not get wiped with oil like having a cap or block with No oil grooves in that area. These two Diagrams I hope show where the oil would wipe, and where it would not. The first one is right, the second one is wrong. The X's are where you would not get a continuous oil wipe. Thanks Herm. Last edited by Kohnke Rebabbitting; 10-08-2013 at 06:10 PM. |
10-08-2013, 05:52 PM | #40 | |
The first one is the model "A" , worn, but you can plainly see the oil well, and spreader groove. Notice where they are laided. Now the second cap a Ford Factory Model "B" cap, with the oil wells and oil spreader groove showen where they were put. the short groove that is in the middle is not factory, as somebody really thought they were going to cause that rear main to stop leaking. That kind of stuff never works. So when you any time move the ends of the oil spreader groove in, you are taking oil away from the area you could have oiled. When the Running clearance gets to great, that is what makes the oil run out a bearing. Thanks, Herm. |
10-08-2013, 06:04 PM | #41 |
10-08-2013, 06:18 PM | #42 |
Herm, you surely do it the correct way. The work looks excellent. Think I have some rods you did for my engine as Elmer LeBrash in Rochester did the babbiting and someone in Iowa supplied the rods. Byers Machine shop in Rochester did the machining. This was about 8 years ago that engine was rebuilt and it runs great. Remember the class Elmer did on babbiting about using a tool that looked like an ear of corn to work the babbit after it was poured and before it was bored to match the crankshaft for mains and rods.
10-08-2013, 06:29 PM | #43 | |
Well maybe if they stay good they are mine, and if they don't I am sure I will have never seen them before. !! thanks, Herm. |
