09-29-2013, 11:38 AM | #1 |
Pan Gasket
Will silicone work for the pan?
09-29-2013, 12:53 PM | #2 |
Re: Pan Gasket
I use silicone ( RTV) at the joints of the gaskets, but no where else. Its slippery, and if the entire block rail is siliconed, the gasket will slip when you tighten the bolts. I prefer to glue the gasket to the block with Permatex high tack, using silicone at the rear main area where the two gaskets join each other and the metal and at the front where the gaskets rest on the oil seals. I do not use sealant on the pan, so it can be easily removed in the future. With a flat pan rail, new gasket and the right amount of even torque, leakage is not a problem.
09-29-2013, 12:57 PM | #3 |
Re: Pan Gasket
FWIW Paul in CT |
