01-17-2012, 03:15 PM | #1 |
1936 sending unit adapter
What kind of adapter do I use for the 1936 temperature sending unit in a 59AB head? Source? Thanks, Ed
01-17-2012, 03:21 PM | #2 |
Re: 1936 sending unit adapter
Ed, Jeg's has ($5)them.On EBAY its item # 200600727747.I have found that you need to bore the hole 1/32 larger as the early Ford bulb is fatter than the temp gauge bulbs on the market today.VDO gauges also has them and some NAPA stores carry that line.Its $8 there.Make sure the male end is correct pipe thread as there are 2 sizes.
01-17-2012, 04:36 PM | #3 |
