04-19-2021, 12:08 PM | #1 |
46-48 Ford hood alignment
What is the best way to line up the hood on the 46-48 Ford cars? I'm just kind of mocking things up right now and I have to push down in the back to get it close enough to latch and the hood sides are really close to the cowl.
04-19-2021, 12:29 PM | #2 |
Re: 46-48 Ford hood alignment
We just discussed this on another site. If you can get a copy of the May/June, 2009 issue of the V-8 Times there is an article with pictures on how it's done. If you can't locate a copy I can snail mail a copy.
04-19-2021, 01:50 PM | #3 |
The article that woodie mentioned is the best reference. Lacking that, most of the adjustment is at the cowl - specifically the bolts that extend under the dash area. Things work a bit opposite of normal meaning that moving things down tends to raise the fit and vice-versa. You also may need to adjust the fenders as part of the process.
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
04-19-2021, 03:10 PM | #4 |
Even if you send it through the copy machine that would be appreciated. If you send magazines via USPS it's like $2 to send "media". I can send you my address. Thanks
04-19-2021, 03:11 PM | #5 |
What do I do about the pinching on the sides of the cowl? Can I just bend it back without affecting anything else
04-19-2021, 03:23 PM | #6 |
Alternatively here's a link to the document: http://marksfordparts.com/articles/a...y-mark-kicsak/
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand http://www.fordbarn.com/forum/album.php?albumid=580 Last edited by meric42; 04-19-2021 at 04:45 PM. |
04-19-2021, 05:13 PM | #7 |
QUOTE=Topher5150;2008821]What do I do about the pinching on the sides of the cowl? Can I just bend it back without affecting anything else[/QUOTE]
Thanks meric42! Can you share a picture or two, Topher?
04-19-2021, 06:53 PM | #8 |
Thanks for the help guys but I have one question. The article talks about two bolts not mine has three
04-19-2021, 07:07 PM | #9 |
Three bolts where? On the cowl? On the hood?
04-19-2021, 07:23 PM | #10 |
On the cowl
04-19-2021, 07:43 PM | #11 |
Nevermind helps if I read the whole thing
04-19-2021, 09:54 PM | #12 |
I had just the opposite problem on my '41 Fordor. the hood sides were way out away from the cowl. After years of messing with it I removed the hinge springs and it fit perfectly. tried all the tricks and NOS hinges. went with a prop rod. A friend of mine painted his '47 and when we attempted to install the hood, it hit the cowl in the center and sides were 3" too high!
