12-18-2014, 05:29 PM | #1 |
Headers
Trying to help a friend on Fenton headers for a 1950 ford convertible! OK I know there's a fit problem on the drivers side with the steering box. I have installed these on my 39 pu with some fitting ! Can I get them to work on the 1950 conv. ? Does anyone have suggestions re this installation and also where can I get a set of pipes made that will fit. Is there a different header that would be better? Thanks Frank pkny
12-18-2014, 07:11 PM | #2 |
Re: Headers
I just bought headers and complete dual exhaust system from Reds Headers for my 35 coupe. Had the tubular headers Jet Hot Coated. Have not attempted to install this system yet, but everything sure looks nice.
12-18-2014, 07:16 PM | #3 |
Re: Headers
Been running my Jet Hot coated tubular headers for a little over 3 years now. Look as good as the day I put them on. Nice thing about tubular is they can be modified to fit quite easily. I've heard some horror stories about making Fentons fit some applications.
12-18-2014, 07:31 PM | #4 |
Re: Headers
Problem is the year 1950 steering box interferes, I love Fentons have them on my ks guys.35 and 39 V8 s looking for a bit of input fitting duels on a 1950 convertable. Than
12-18-2014, 07:46 PM | #5 | |
Re: Headers
You asked if there was a different header that would fit better, so in my opinion, I believe Reds tubular headers would fit/work better than Fentons, probably on any early Ford with a FH V8 engine.
12-18-2014, 11:17 PM | #6 |
Re: Headers
12-19-2014, 01:09 AM | #7 |
Re: Headers
These are the LH optional manifolds Ol'Ron is talking about. Originals seem to have become near impossible to find.
12-19-2014, 02:09 AM | #8 |
Re: Headers
Shoebox-central.com..... Pat Rooney also. Posts on here as Pats52 I think..... You can dual exhaust manifolds from either of these sources......Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
12-19-2014, 09:17 AM | #9 |
Re: Headers
I have Fentons on my '51 club coupe and have had them for the last 25 years. They are close to the steering box, but they are in there and work well. I think the fact that they have been there this long tells you why people like them. I'm sorry I can't tell you what had to be done to make them fit, as the installation was done at a Midas shop owned by a friend. All I know is that it took a day, and nobody there mentioned having any kind of problem. As a matter of fact, I didn't know they "didn't fit" shoeboxes until I read it on the H.A.M.B.
I also had them on a '50 Merc in my '36 3 window. I put those in myself and got them in by swapping in a '37 steering gear and some judicious grinding on the headers themselves and the steering box. Last edited by tubman; 12-19-2014 at 10:29 AM. Reason: Forgot something. |
12-19-2014, 09:35 AM | #10 |
Re: Headers
Grinding on the heads?? I put Fentons on my '35 tudor sedan with '37 steering box. It required a lot of grinding on the headers and a little on the steering box, but nothing on the heads. I now wish I had done Reds Headers instead.
12-19-2014, 09:50 AM | #11 |
Re: Headers
Hi all; Good old Bob Drake's; He makes the factory Lh for 49-51 and 52-53. two different manifolds. Newc
12-19-2014, 10:28 AM | #12 |
Re: Headers
Ooops! Headers, not heads; corrected the original post. Once they're on, they're great. Had noise, fitment, and durability problems with tubular headers years ago, and try to avoid them. Has Red done something different to make his current ones better?
12-19-2014, 11:41 AM | #13 |
Re: Headers
have fentons on my 39 std with an 8ba, just had to have the flanges milled, tight, but fits.
12-19-2014, 01:13 PM | #14 |
Re: Headers
Ole39
How much needed to be milled for fitment? Thanks Jim |
12-19-2014, 01:19 PM | #15 |
Re: Headers
Frank,
I'm working on a '50 club coupe and am going to use Pat Rooney's LH manifold with John Kepich's (?) pipes and mufflers. Sorry I can't tell you about installation but Pat copied the LH manifold that Ford installed on police cars of the era. I understand there were two different configurations, '49-'51 and '52-'53. I first ordered the Drake manifold and found it to be unacceptable. The rear outlet was no bigger than exhaust ports coming out of the engine. Pat's unit better matches the size of the exhaust pipe. By the way, Shoe Box Central sells Pat's manifold. There's another thread on here that may give you some insight. It's on a '51 and should be the same or close. Here's the thread: http://www.fordbarn.com/forum/showthread.php?t=157199 How's the weather down there? We moved up here from Rhinebeck in 1998. Howard Last edited by HCO41; 12-19-2014 at 01:22 PM. Reason: spelling |
12-19-2014, 01:37 PM | #16 |
Re: Headers
Go to Red's Headers, he'll have the right headers and be able to bend up the exhaust system to match.
http://www.reds-headers.com/
Nomad |
12-19-2014, 02:29 PM | #17 | |
Re: Headers
12-19-2014, 02:44 PM | #18 |
Re: Headers
Reds does not have cast headers that will work . will try the recommended ones on the previous quote. Thanks
12-19-2014, 02:48 PM | #19 |
Re: Headers
Rhinebeck has been invaded by cityidiots weather is fine the nitwits are the ruling class around here, if I could i would bail.
12-20-2014, 01:01 PM | #20 |
Re: Headers
