06-06-2021, 06:40 PM | #1 |
81T from a '41 truck should still be a 221ci, correct?
Hi All:
I went to go look at a motor today. Supposedly out of a '41 truck that was wrecked and then used to power a saw mill. The truck part seems to check out. 81T heads and a heavier duty fan. If I'm correct, all 81T's were 221 ci motors, right? Thanks, Tim Last edited by Tim Ayers; 06-07-2021 at 12:38 PM. |
06-06-2021, 07:12 PM | #2 |
Re: 81T from a truck should still be a 221ci, correct?
yes they were! in 39 and more prominent in 40 up could be 95 hp mercury version but not in 38
06-06-2021, 07:30 PM | #3 |
Re: 81T from a '41 truck should still be a 221ci, correct?
I don't think it is. I tried to find the stamp in the corners of the block. It does seems to have the raised intake surface. The story of it coming out of a '41 truck seems plausible. I kind of know the saw mill the gentleman was talking about.
06-07-2021, 12:29 PM | #4 |
Any other thoughts? Google is making my dizzy. Keep reading that trucks in '41 may have gotten the 239 ci motor. I wish the heads were off this motor so I'd know for sure.
06-07-2021, 01:03 PM | #5 |
I got a similar engine from an old doodlebug. I pulled heads and did a shade tree valve job and put it in my 39 Tudor just to " sort things out". Getting ready for its first drive in 50 years. Engine starts instantly and has good oil pressure. Sounds like a sewing machine. Wife was pissed I spent 75.00 on the doodle bug.
06-07-2021, 01:04 PM | #6 | |
06-07-2021, 02:42 PM | #7 | |
" Original cylinder heads for 1938 to 1942 were generally marked with "81T" for truck engines from 1938 to 1942; "99T" for 100hp Ford Truck and Mercury in 1939 to 1941; and "29A" for Mercury in 1942. " |
06-07-2021, 04:30 PM | #8 |
What is on the bellhousing, a big A and are there two bulges on each pan rail side?
06-07-2021, 04:46 PM | #9 |
06-07-2021, 04:49 PM | #10 | |
Coop, Thank you. I'm leaning towards it being a 221 as well. I went to look at it after a long hot day of fishing, so I wasn't on my A game. I did briefly look at the front corners for a 99 stamp and didn't see it, but it was kind of dark in the shed. Not that a 221 is a bad engine, but I've got some cracked 99A's and don't need another boat anchor at this point. I'm looking for have one good spare block for a future build. |
06-07-2021, 05:52 PM | #11 |
The original engine in my 40 Tonner has 81T heads and was 221 CI prior to boring to 239 CI during the rebuild. It wasn't sleeved.
06-07-2021, 07:59 PM | #12 |
There is no way to know for sure without pulling the heads. After 80 years, who knows what has been done.
06-08-2021, 07:08 AM | #13 |
06-08-2021, 07:23 AM | #14 |
