Old 04-25-2018, 10:00 AM   #1
JSeery
JSeery's Avatar
Default K & S Gauges
A recurring subject is K & S (original Ford) gauges and issues on how they work and how to test and/or repair them. I put together a PDF file from past threads on the subject. Hope the contributors don't object to having their information included. These include Tubman, 19Forty & Deucemac among others.
Old 04-25-2018, 10:11 AM   #2
Seth Swoboda
Seth Swoboda's Avatar
Default Re: K & S Gauges
Interesting piece. Thanks for putting that all together.
Old 04-25-2018, 10:16 AM   #3
tubman
tubman's Avatar
I think it's a real good idea to do this. You can bet this one will get printed out and put in he proper place in my file cabinet.
Old 04-25-2018, 10:19 AM   #4
Seth Swoboda
You bet and I already have mine three hole punched. Wow, am I a nerd about this stuff or what?
Old 04-25-2018, 10:21 AM   #5
19Fordy
19Fordy's Avatar
JSerry: Thanks for getting all the info together in one place and explaining it.
Do you think it would be possible to replace that "second wound resistor " with a modern 8-9 ohm resistor and still have the gauge read accurately?
If so, which of the resistors shown in link below do you think could be used?
https://www.radioshack.com/pages/sea...ohm%20resistor
I am not good with electronics so need all help I can get.
19Fordy is online now   Reply With Quote
Old 04-25-2018, 10:32 AM   #6
Kahuna
Kahuna's Avatar
J,
Thanks so much for the effort.
Well done
Jim
Kahuna is offline   Reply With Quote
Old 04-25-2018, 10:34 AM   #7
cmbrucew
cmbrucew's Avatar
JSerry
That is a nice piece of work. As others have said " I will keep it with my flat head doc's, and my electrical stuff.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 04-25-2018, 10:53 AM   #8
JSeery
JSeery's Avatar
I can think of two issues. The first is heat, the original was designed (I think) to dissipate a lot of heat. And secondly they (again I think) were used to calibrate the sender unit. Might be worth a trial and error effort.
Old 04-25-2018, 11:12 AM   #9
19Fordy
19Fordy's Avatar
Mr. Seery: Because it dissipates heat, does that mean that the 8 ohm resistor would have to have a high wattage rating, if so what rating/ I found some on ebay that are 8 ohms with a 10 watt rating.
I was also thinking that if a larger size resistor with higher wattage is needed it could be mounted on the outside of the fuel tank sending unit with insulated wires running to the connections inside the gas tank sending unit.
I know Watts = V x A. What amperage is used to operate a 6V Ford fuel gauge?
Old 04-25-2018, 12:03 PM   #10
tubman
tubman's Avatar
Nope, probably a guy like me who doesn't have internet access in his shop.
Old 04-29-2018, 07:07 AM   #11
RobR'35
RobR'35's Avatar
Great write up of info in one place.
Thanks, it's much appreciated.
RobR'35 is offline   Reply With Quote
Old 04-29-2018, 08:25 AM   #12
Darrell S
Darrell S's Avatar
Very well done, it is in my file. Thanks much.
Darrell S is offline   Reply With Quote
