04-12-2019, 04:36 PM | #1 |
Banjo saga continues
So I completely disassembled the carrier and i removed all the bushings and races . The only thing i couldn't do was to remove the pinion gear from the drive shaft.
At first i though the carrier bearings were tight. But once I took the axles off I could turn the inner part of the bearing by hand. It's a little stiff and still had to hammer and chisel it off because there was a slight lip on the end of the carrier. Looks like I will have to have the carrier knurled. |
