Old 09-20-2015, 03:04 PM   #21
GearRat
GearRat's Avatar
Default Re: GearRat's '35
Hello all,
Long time no see! We recently started working on the '35 again. The engine fired up for the first time in at least 20 years so we are excited about that (link to video below). I've currently been working on rebuilding the fuel pump and carb. So far the fuel pump is rebuilt and only the carburetor remains. Question though.... We got Berryman chem-dip and set the carb in there to clean but, we left it in there and were busy taking care of other obligations. So it has sat for about a week and a half in the cleaning solution and now it has a flat light gray finish. Is this bad?
Thank you,
GearRat
https://youtu.be/U_S1M3e_Ad0
GearRat is offline   Reply With Quote
Old 09-20-2015, 03:16 PM   #22
GearRat
GearRat's Avatar
Fuel pump before and after...
Old 09-20-2015, 03:19 PM   #23
jmaotto
Looks like two different fuel pumps.
jmaotto is offline   Reply With Quote
Old 09-20-2015, 03:23 PM   #24
GearRat
GearRat's Avatar
Didn't capture a before photo, but there was another pump in the trunk that looked very identical to its prior condition.
Old 09-20-2015, 05:59 PM   #25
COE Dan
Originally Posted by GearRat View Post
Hello all,
Thank you,
GearRat
You'll find that many (most) original carbs are a dull gray now as the survivors have been cleaned using chemical dips (of various types) over the years. Mine are all that way and it doesn't appear to affect performance. If you're looking for a concours level look, there many be folks who can restore the original finish. Others may know more.
COE Dan is offline   Reply With Quote
Old 03-12-2016, 03:50 PM   #26
GearRat
GearRat's Avatar
Hey there guys!
Trying to track down a radiator for the '35 is a pretty difficult task. Is there a company that you all would recommend as far as getting a new radiator? I cant seem to find any if at all radiators for this car.
Thank you,
-GearRat
Old 03-12-2016, 04:37 PM   #27
Phil Gillespie
Phil Gillespie's Avatar
Look at Swap Section at present there are some 35 and 36 radiators for sale.
Could require work?
Phil NZ
Phil Gillespie is online now   Reply With Quote
Old 03-12-2016, 04:38 PM   #28
PeterC
PeterC's Avatar
Hey there guys!
Thank you,
-GearRat
Original radiators are out there .. I sold two nice ones in the past - check ebay - put a wanted ad on this site - also some of the forum members specialize in parts for the 35 and may have some to sell.
PeterC is offline   Reply With Quote
Old 03-12-2016, 04:55 PM   #29
Tinker
Tinker's Avatar
Brass works isn't cheap but have good reviews. A used swap radiator might need a recore. Recores aren't cheap either. Best to get the best radiator you can afford to get, it'll be worth it in the long run.
http://www.thebrassworks.net/shop/Re...6b9ada5829ec0d
Old 03-12-2016, 05:22 PM   #30
Randy in ca
Randy in ca's Avatar
Note that there are two styles of the '35 radiator - these are both shown on the Brassworks link. Your body appears to be an early version but you may want to post a few pictures of the radiator rod firewall brackets if you're not sure.
Randy in ca is offline   Reply With Quote
Old 03-12-2016, 06:01 PM   #31
tiquer
Hello all,
Thank you,
GearRat
I havw used Pinesol to clean my carbs and fuel pumps and rinced them off in a good cleaning solvent it worked very well
tiquer is offline   Reply With Quote
Old 05-03-2017, 03:15 PM   #32
GearRat
GearRat's Avatar
Not an expert on flathead v8's so I'd appreciate feedback on how ours is idling. Adjusted the idle screws a bit as the plugs were pretty sooty. We are also running with open manifolds right now so any noises are amplified.
Here's the link to see the video: https://youtu.be/aO0fNHoUrU0
Thank you!
Old 05-03-2017, 06:24 PM   #33
russcc
Fort Wayne is the way to go. Quick turnaround, excellent service. I just bought a Aetna throw out bearing from them, Made in the USA in Franklin Park IL. The best there is.
Old 05-04-2017, 11:56 AM   #34
rotorwrench
rotorwrench's Avatar
It doesn't sound too bad to me. Manifolds and exhaust should improve performance a bit. They need that for proper scavenging.
I bet your a happy camper to have it running again. You've been at it a while.
